Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
My chainsaw starts but will not run when trigger is pulled
Carb gasket was changed and it ran a little longer.fuel lines were cleaned and spark plug is new.
steve_lima
  • 181 Answers
SOURCE: 455 Husqvarna chainsaw will not run
pull the muffler off and look for scoring on the piston,the 455 had a problem with running lean from factory and burned up a lot of pistons and cylinders
Posted on Jan 09, 2009
  • 226 Answers
SOURCE: Craftsman Chainsaw will not start
It's your ignition, which you can take that stuff apart on the left hand side of the saw under the recoil. I have 2 of these, & you can get the parts. Maybe its just the magneto gap adjustment, which is like a business card or newspaper width gap. I would check that first. Hope this helps you, Rick
Posted on Apr 29, 2009
nobby63
  • 10 Answers
SOURCE: chainsaw wont stay running
check crankshaft seals,maybe sucking air. most of the time the seal on the starter side. hope this helps.
Posted on Jul 09, 2009
luckyluke78
  • 333 Answers
SOURCE: Husqvarna 40 Chainsaw won't start
The carb uses the pulses from the crankcase to actuate a diaphram in the carb as the fuel pump.If you strip the carb make sure there are no perforations/cracks etc. on these diaphrams and check too that the valve flaps are OK.if not fit a carb kit.
Also check that the pipe or channel from the carb to crankcase is OK.
If all this is correct you can simply put your hand behind the carb or inlet to check for vacuum if not there you have probably blown a crank seal(but unlikely)and you will have to replace them.
Hope this helps,and please come back if you need any further assistance.
Posted on Aug 10, 2009
Testimonial: "Thanks again luckyluke I did find it and was able to clean it through I'm still having the problem of not starting though, carb kit next 90lb cyl comp"
  • 302 Answers
SOURCE: Husky 345 chainsaw will only run with choke almost
turn both carb adj. screws out 1 1/2 turns from bottom and then fine tune them with it running. the one marked L is for low speed and the one marked H is for high speed. hope this helps
Posted on Sep 08, 2009
Why chain saw will not start
1) Check if it fire! If not! change spark plug!
2) Fill fuel tank, Pull spark plug ou, turn upside down chainsaw, if fuel drip from the cynlinder than you need to change carb gasket.
3) check if the bubble primer is not puncture. If so need to remplace it!
4) Clean the gunk!
Jun 23, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Homelite chainsaw is hard to start and stops running after 5 to 10 seconds.
Could be the filter in the tank or the cap. The tank needs to be vented to allow fuel past the filter.
Jul 03, 2012 | Homelite Garden
I have a poulan 3000 chainsaw that i replaced the fuel lines on, it does not have a primer bulb, just a fuel line with filter, vent line and impulse line, now it wont start at all, if i let it set for a...
If the plug is soaked, then the needle in the carb is most probably leaking, you need to do a pressure test on the carb to prove this, if you do not have a pressure tester it will be a case of replacing the needle and hope for the best, make sure the gasket goes on before the diaphram, it acts as a spacer.
Aug 09, 2011 | Poulan Garden
Craftsman gas leaf blower will not start. Spark and gas lines ok. Not getting gas to plug even after prime and several pulls. How do I find gas supply problem. Diaphram in carb looks ok .It actually...
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 25, 2009 | Craftsman Garden
My Husqvarna 350 chainsaw won't stay running. Changed spark plug and fresh gas. Please help if
1) spark plug
Chain Saws:
Remove Carburetor
Nov 25, 2009 | Husqvarna Garden
I have an etco chainsaw that will only start on the choke and stops almost immediately. The carb has been cleaned and a new diaphram fitted. A new fuel filter has also been fitted and spark plug. The spark...
Basics to check:
- aluminum or silver - piston/cylinder scored
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
1) spark plug
ChainSaws:
Remove Carburetor
Please double check the gasekts/diaphragms for proper installation
Nov 12, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My Poulan Pro 260 chainsaw will start and run when the choke is pulled out, but as soon as I disengage the choke, the saw dies. Do I need to have the carbuerator checked?
It is running in a lean condition. Continued operation like that can cause piston and cylinder failure.
I'd take it in for repair estimate ($10) at the local chainsaw seller/mechanic. Explain the problem you are having, Probably a leaking fuel line. I'd expect a repair and tune up about $40-60. Your saw will perform better and your arm will thank you. If tuned ask what fuel/oil ratio they used (should be 50:1) and affix a label to your fuel tank. HTH
Lou
Nov 08, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 220 saw starts & runs fine when finger on throttle, will not stay at idle. Rplaced plug & same issues.
All you need to do is try to adjust the throttle idle speed or else a cheat would be to tighten the cable which means the cable will be pulling very slightly the throttle which means it will remain running when u release throttle.
Nov 05, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
