Question about Breville ESP8XL Espresso Machine
Hot water won't flow into machine
I just bought brand new Breville espresso machine. When I plug in the machine and turn it on, it heats up the water and is clearly humming, but once the meachine is heated and I turn the dial, nothing happens. No water flows into the coffee grinds, therefore no espresso can be made... Any thoughts on what could be happening here?
  • 2 more comments
  • Anonymous Nov 17, 2007
    took apart no flow or suction from water tank. No blockages It heats up, you can hear it try to work but no water flow. Any other suggestions besides priming
  • Anonymous Jan 10, 2008
    I fixed it ! Breville ESP 8XL It was hard water deposit. To Resolve problem when pump is working but no water comes through.
    1st fill resivior 1/2 way with 1 part white vinigar 1 part water turn on machine turn on to left for steam for 7 seconds off to middle for 1 second then to right for 7 seconds repeat these steps 7,8 possibly 9 times should work did for me good luck.
  • Anonymous Mar 11, 2008
    same problem... the bugger won't let any water go through. Tried reaching in with my hand, didn't do anything...
  • brianbar Aug 07, 2008
    I seem to have the same problem. I just bought the maching and it hums and sounds like it it trying to pump water through the machine but nothing happens. I have let it run for at least a min. Does it need longer then this to prime, or is it likely a malfunction?
We stumbled across a solution to this same problem by filling the reservoir about half full, putting it in place, and reaching down to the bottom (small hands required) to pull the plunger open. The machine was running at the time, set to run water through the filter holder, which had no grounds in it. It may not be necessary to have the machine on. Good luck, Gene
Posted on Dec 26, 2007
    Problem Solver:
  • 11 Answers
You most likely need to prime the brew head. Follow the instructions in the owner's manual. To prime the brew head, you'll need to put run the machine without coffee until water starts flowing. One water flows, the brew head is primed and the machine is ready for normal use. You'll need to do this every time you run out of water. Regards, Denis
Posted on Oct 09, 2007
SOURCE:
When turned on for heating the water does not stop flowing into drip tray
When you say the water does not stop flowing? when you are in steam or hot water mode?
Apr 16, 2016 | Breville Die Cast 800ESXL Espresso Machine
Brand new breville 800esxl espresso machine will not pump one drop of water - makes all the appropriate noises - shut it down - waited for it to cool - still no water
Hi I bought a Breville today and had the same problem. I found the following suggestion and tried it. After 5 goes my machine worked - yippee - hope you have success too. Info below noavatar.png c280sportguy
  • Rank: Apprentice
  • Rating: 100%, 11 Votes
I got through to the tech support at Breville and they helped me fix this problem. What they had me do was:
1)Fill the water tank all the way up
2)Turn the power on and wait until the heating light turns off.
3)without coffee in the head turn the machine to espresso mode and let it pump for a minute.
4)after a minute turn to standby for a couple seconds then turn it to steam mode for a minute.
5) after this minute is up turn it back to standby for a couple of seconds and then back to espresso mode.
6) the technician said to do this seven times, but mine started working after three or so. The tech said the fixes about 80 to 90 percent of machines with this problem.
Good Luck!
Sep 14, 2011 | Breville Die Cast 800ESXL Espresso Machine
Makes espresso, coffee, water, but will not steam
The pump has gone bad - through use. This is a common problem, and has to do with the "seals" that are in the pump. Since the pump generates high pressure and heat, over time, the seals will fail, and will be unable to generate enough pressure and heat to create steam. The only remedy is to have the pump replaced through the Breville Out of Warranty repair centers.
http://www.brevilleusa.com/support/service-centers.pdf
Dec 11, 2007 | Breville Die Cast 800ESXL Espresso Machine
Power light will not come on.
There is a post with a solution for this with the title: "Machine won't turn on - no power! " - fixmebob has a good solution, but you'll need to be a little tech savvy to perform it yourself. I ended up sending mine in for repair, which ended up being about $55 because I had to ship the machine. But good news is that I'm back up and running.
Nov 18, 2007 | Breville Die Cast 800ESXL Espresso Machine
No water is being pumped at all
Good Luck!
Nov 04, 2007 | Breville Die Cast 800ESXL Espresso Machine
Breville ESP8XL Espresso Machine Logo
1,229 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Ekse
superdad1976
Gene Pitts
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
