Question about Maytag Neptune MAH6500A Front Load Washer
Maytag neptune MAH6500AWW model cold water won't fill
zeusfaber
  • 247 Answers
SOURCE: Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Posted on Feb 06, 2007
  • 1073 Answers
SOURCE: maytag neptune modle MAH6500AWW
it is saying locked rotor situation, could be a loose connection at the main board, at the door switch or the motor is bad, bet motor kit # for motor and board 12002039 good luck with the repair
Posted on Apr 12, 2008
  • 245 Answers
SOURCE: My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
Posted on Apr 30, 2009
milten1
  • 1304 Answers
SOURCE: Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Posted on Oct 10, 2009
wpcustomer
  • 362 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    Maytag Neptune MAH6500AWW '03 front load nf code it is OVERFILLING won't shut off, water pouring out door! new drain pump last week & checked hoses in front 2 days ago. now this, help?
    nf stands for no fill, so this means the washer's water level sensor is defective or plugged with dirt. That is why it is overfilling.
    Nov 09, 2016 | Maytag Washing Machines
    I have a maytag neptune washer model MAH5500B and the error code is "Lr"; what does this mean?
    your machine has a fill problem either your screen is pluged on the water hose either hot or cold or your water is turned off.
    Sep 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
    The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
    If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
    Washing Machine Problems No Water
    Washing Machine Fix Washing Machine No Water
    heatman101
    Sep 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
    My Maytag Neptune will not spins and gives the code nf. I have been told that there is a reset code. Does anyone know the code?
    Hi
    Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water.
    Try running the diagnostic test by—
    • Press the delicates and heavy soil keys together for 3 seconds.
    • You are in the service mode.
    • Now, press wrinkle free key, cold water should start entering.
    • Then, press the cotton sturdy and hot water should flow.
    • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
    Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Aug 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Maytag neptune washer wont fill water
    It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
    Jan 10, 2010 | Maytag MAH6700AWW Neptune Front-Load...
    I have a Maytag Neptune MAH6500AWW mOdel. Less
    YES YOU CAN , CONTACT PLUMBERS SUPPLIRES WITH MODEL NUMBER OF MACHINE AND MAKE FOR BERINGS WHEN YOU HAVE THEM YOU CAN START, FIRST MAKE SURE POWER IS OF THEN LOCATE SKREWS IN THE MACHINE PANEL, REMOVE AND OPEN PANEL LOCATE BEARINGS AND REMOVE BRACKET HOLDING THEM IN AND REPLACE NEW ONES , IF YOU OPEN MACHINE AND HAVE A GOOD LOOK YOU WILL FEEL MORE CONFIDENT, GOOD LUCK.
    Oct 22, 2009 | Washing Machines
    Maytage MAH6500AWW Overloaded washer now leaks when filling
    since you can drain it
    take off the back and watch what happens when u turn it on
    i believe you make have a loose drain connection
    Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
    Only hot water will fill, cold water will not
    If it is equipped with ATC automatic temp control turn it off and see if if you can get cold if so its the ATC sensor
    Sep 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
    Maytag neptune modle MAH6500AWW
    Apr 12, 2008 | Maytag Neptune MAH6500A Front Load Washer
    Maytag Neptune MAH6500A Front Load Washer Logo
    26 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
