Question about Tanaka 22" Double Sided 24cc Hedge Trimmer
Does a THT 2520SB have a clutch?clutch
Cutter is slipping
Clutch cable
to determine the actuall adjustment to the clutch lever run ur machine as normal on the 2nd gear and then reduce the speed teh gear will slip tightn up the lever till tht play goes away ..and do let me know
May 31, 2008 | Harley Davidson Road Tech HA90 MP3 Player
My remington electric chainsaw 3.0 is not cutting and making a high pitch screech when i go to cut with it
Hello. Please make sure the saw brake is not set. This locks the blade so it cannot spin. If it is locked then if you try to rev the saw, the blade cannot turn and the clutch will scream. The other thing it could be is it sounds like the chain is out of the groove and the clutch is slipping BAD. UNPLUG the chainsaw. Check to make sure the chain turns freely around the cutter bar. If it does not move at all, you will need to closely examine the cutter bar to see if it has 'popped' out of the guide path. You must also make sure the chain is on the drive gear correctly.
These are 2 things to look at that can help you. Hope this helps..
Nov 04, 2012 | Remington Garden
Tanaka tht 2100-very difficult to start. Pull cord is is either too loose when pulled or it is jumpy, meeting with a bit of resistance?
i think it sounds like the motor is going i had a chainsaw and it did the same thing after a while the motor went and the chainsaw was no good anymore so you mite want to take it to a dealer that deals with your grass trimmer
Sep 03, 2012 | Tanaka Commercial Grade "Inspire" Design...
Give me please a step by step to unblock my smart sim and phone, i lost my PIN/PUK slip
omg tht happened to me i had to call at&t or watever network you had n i had to give them the MEI or watever tht number is on the back of the phone n they gave it to me hope tht helps u hun ;)
Apr 28, 2010 | Cell Phones
Acme juicer vibrating so much.
I've had one for 21 years and when I replaced the blade the same thing happened.
The blade is not supposed to be held firmly in place so it can slip intentionally to
minimize vibration. If you bought the juicer new, think back, and I believe you will
remember the vibration problem. I seems with a worn blade they vibrate less. The
motor is very durable and uses roller bearings like on a skate board. I went back
to the old blade, which I sharpen with a drill using a small bit.
Jan 11, 2010 | Acme 6001 Juice Extractor
Trimmer head does not turn as fast as it should. It seems like it is slipping b/c as soon as there is any resistance (place trimmer head flat on ground) it stops. Engine sounds good. Possible connection in...
Maybe, but it sounds as though the clutch may be the problem. If you can get it to run properly except for the turning of the head, check the clutch. If it is just not running with high enough RPM's, the problem may be the engine. I would check the clutch...I may be wrong and it may be the shaft. That would be an easy fix...Lee
Aug 25, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Have a recoil pull start mower that won't recoil
the starter clutch probably needs cleaning. It is located right on top of the fly wheel. Pull the the pull rope housing off and you can see it
Apr 04, 2009 | Poulan "" Push Mower
Tanaka 22" Double Sided 24cc Hedge Trimmer Logo
32 people viewed this question
Top Tanaka Garden Experts
john h
Nick Olsen
Are you a Tanaka Garden Expert? Answer questions, earn points and help others
