Question about Denon DRA-395 Receiver
Tuner - When BASS it goes MONO
Hello all, my DENON amp, is not tuning right (from the date it was bought). This is what it does: 1. I tune in to a station. The freq. is right and locks. 2. It tunes in Stereo 3. Then, as I am listening to the music, when there is bass music or voice, the Stereo indicator blinks to the rhythm of the bass. Also, the RDS inidcator is blinking to the same rhythm. The audio is very annoying, going stereo-mono to this rhythm! I have tried with stations all the way from 87,5MHz to 108MHz. The problem remains... The tuner, a Shen Zhen SH-2294VO is very complicated for me. It has lots of trimmers and I don't know which to try to fix this weird problem. I am uploading 2 pictures of it... If you can point me to the right knob/trimmer, I would be grateful! http://www.picoodle.com/view.php?img=/9/10/9/f_SH2294VO1m_32c32c5.jpg&srv=img32 http://www.picoodle.com/view.php?img=/9/10/9/f_SH2294VO2m_a0fcb1b.jpg&srv=img32
  • lexios Oct 11, 2007
    Yes I did, there is a 75Ohm connector at the back. I connect the included antenna (a bipolar long cable) that came with the unit.
    Do you think I need to use external antenna?
  • 93 Answers
Did you check antenna connections?
Posted on Oct 11, 2007
SOURCE:
Have Denon AVR-2313ci receiver. FM tuner quit working; will tune in 50 MHz steps, on every step "stereo" and "tuned" are lit but no sound comes out whether actual station or not.
There is no module per se. Tuning is accomplished by applying a voltage to the tuner chip and their associated circuits. It needs to be repaired by a Denon service center.
Oct 25, 2016 | Denon AVR2313 7.2 Channel A/V Receiver
What are the tune r numbers
For 6 STRING GUITARS, tune strings in
ASCENDING ORDER: Target Hz
For 6 string guitars. Tune in ascending order
First LOW E . . . . . . . . . . . . . . . . . 82.4
Second A . . . . . . . . . . . . . . . . . 110.0
Third D. . . . . . . . . . . . . . . . . . . 146.8
Fourth G. . . . . . . . . . . . . . . . . . 196.0
Fifth B . . . . . . . . . . . . . . . . . . . 246.9
Sixth HIGH E. . . . . . . . . . . . . . . 329.6
For 4-5 string BASS GUITARS, tune strings in
DESCENDING ORDER: Target Hz
For 4 and 5 string Bass Guitars
First G . . . . . . . . . . . . . . . . . . . . . 98.0
Second D. . . . . . . . . . . . . . . . . . . 73.4
Third A. . . . . . . . . . . . . . . . . . . . . 55.0
Fourth E. . . . . . . . . . . . . . . . . . . . 41.2
Fifth B (if 5 string) . . . . . . . . . . . 30.95
The manuals are here.
http://www.snarktuners.com/contact-service
Jan 16, 2016 | Snark Clip-On Guitar & Bass Tuner
Don't know how to turn on tuner
put a battery in your guitar. It goes in the space at the bottom, usually where you connect your cable to your amp.
Then hold the guitar as you usually would.
Look for a little board with buttons on the side of the guitar to turn on the tuner: )
Mar 27, 2014 | Ibanez Talman Acoustic/Electric Guitar
I tune my bass guitars on the tuner no problem, i have recently tried to tune an electric guitar, but the tuner locks up... any suggestions please.... Thanks ... J
Make sure you have adequate input level to the tuner... some guitars MAY have inadequate output to be recognized CONTINUALLY by the tuner.
Jul 05, 2011 | Korg GB-1 Pitchjack Plug-In Guitar and...
I do not know how to connect the woofer KEF PSW3500 to the amplifier Denon 4310. BCC sold me a 1 on 1 plug, but the woofer needed to plugs (left and right).
Bass is mono directional in the main,and while your sub has a left and right input ( because a few amps do have left and right sub outs) only one of them is required (usually marked as MONO on the sub). You can also get a Y splitter phono adapter and connect the single cable you have to both sockets, which is how I have mine set up. This is most common
Dec 03, 2010 | KEF Audio PSW3500 Subwoofer
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
Can't get clear sound when not in "bypass" mode on Denon Pro Logi
From the FM radio mode, from your remote press the speaker button to make sure just the front speakers are on, make sure surround is off and use the tone cotrol button on the right side of the amp to adjust the bass and treble. That should clear things up a bit
Feb 25, 2009 | Denon AVR-2802
Sony gtx 500 cd deck/ kenwood 8104d tuning
Set your HPF and LPF on the headunit to match the crossover on the kenwood amp.
I have the same amp, it's really not difficult to figure out. Try these settings, For the AMP: Bass Boost: 0 Crossover: 150 Level: 1
Now just go into the menu for your head unit and make sure you set the crossovers to 150 or whatever option you have, just make sure they match.
Simple.
Feb 27, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Denon DRA-395 Receiver Logo
121 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
