Question about Intel Motherboard
Problem with front audio, i get sound with the back panell but not form the front the speakers and head phones work fine please see if you can help thanks
  • monie123 Dec 17, 2007
    msi agp 8x n mainboard
Also, depending on your motherboard, some may have option to choose front audio as ac97 or HD, it may be default set to HD, therefore when you hookup front panel audio connector thats ac97, it will not work.
Posted on Oct 16, 2007
  • 196 Answers
In some boards I've seen, the front connectors are not connected by default.You may need to review the manual.
Posted on Oct 10, 2007
4 Suggested Answers
SOURCE:
SOURCE: Audio Jack Problem
check any other driver installed before the current driver......
Posted on Aug 16, 2007
SOURCE: how to connect the headphone in front
plz use audio cable extenction
that comes in 2$ at any pc hardware shop
Posted on Dec 17, 2007
map9966
  • 2351 Answers
SOURCE: Front panel audio failure-DG33FB Intel mainboard
Your Intel DG33FB board by default was already setup for use. Your board has been configured for independent multi-streaming 5.1 audio (using the back panel audio connectors).
Your board should have come with a shielded front panel audio cable to connect front panel audio as shown on page 45, item B. The pin out for the front panel audio header is shown on page 46, table 5.
If you did not receive this cable you may need to contact Intel.
Check the Intel link included, which shows the cable needed for either AC'97 or HD cabling;
Audio standards: AC'97 and HD audio
Most motherboards will not play audio through the rear jacks when the board is connected to the front audio pins.
Intel like other manufactures do not mention this in their manuals.
Thanks for using Fixya!
Posted on Jun 03, 2009
04 Infiniti sedan w/ factory Bose. Front speakers are not working (no sound at all) and I adjusted fade all the way both ways. Back speakers are fine. What's up?
If the rear speakers are fine, perhaps I can narrow this down. Fuses must be OK. Steering wheel audio controls connect to the audio unit which has a preamp function. The W/BK outputs connect to the left front inputs of the Bose speaker amplifier; the GRN/RED outputs connect to the right front inputs. Your ear test confirms the front door speakers are not working, therefore there is no front door output from the amplifier. The amplifier stages for the front doors may not be working or no front door amplifier input is being received from the audio unit. The fader and balance controls do not show on the diagram so must be on the front panel. They could be defective. There is a remote possibility of broken/disconnected wires
Sep 07, 2012 | Sony 2003 2004 03 04 Infiniti G35 Bose Am...
My speakers are not working plugged into the back of the PC. They are working when I plug them into the head phone jack in the front. Is my sound card bad?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 22, 2011 | HP Computers & Internet
Sir, I am 58 yrs old having an interest in computers.I have Two Problems.I hope you will extent your help with your knowledge and expertize in solving the problems. 1. The front audio panel when fitted...
As per your information, there might be some problem with front panel microphone.
1(a). please check the internal cable for audio from motherboard to front panel. if possible change the internal cable.
1(b). If not avoid using the front panel and use the extention cables for extending from back points of speaker connection and microphone connection. just like usb extention cable you will find the audio/mike cable extentions can be found in local electronics shop. so that when ever you want you can connect speakers or headphone and also microphone.
2. For entering to BIOS, use either DEL key or F2 key when you power on the pc. In that you can see all the features. -
May be this helps to you.
Jun 17, 2011 | ASUS P7H55-M LX Motherboard
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
My desktop speakers not working but cable all plugged in and audio device working.
Hi tamjidzaee ,
Please follow the below steps to solve the problem that you have mentioned :-
  1. Check if the sound driver has been installed in your system, you can check this by going in the control panel's sound and audio devices option , if you find all options disabled and it reads no playback devices and no recording devices, then you have no sound driver installed. Therefore in this case you would require to install your sound driver using your motherboard cd.
  2. If you see your sound driver is installed in the audio options of the control panel and you also see the sound driver's name , then you need to check the volume in the volume settings to check if it has not been muted accidentally , if it has been muted , then please un mute it and things should work fine.
  3. A good idea would be use a headset and plug it into your motherboard in the slot where the speakers output is received , mostly the green round slot.
  4. If you have a front head phone option then you can try using it as well, if the headphone or headset works fine, then we are sure about two , things that the driver is installed successfully and there is a sound output from the audio output slots.
  5. Now, when you have checked the sound via headsets then you need to make sure that you are connecting your speakers in the green slot or the same slot which is working for headsets, remember headsets can be used to check the output in the back panel of your cabinet as well as front panel of your cabinet.
  6. Also check if there is any fuse in your speaker which has blown up so that you can replace it and it would start working, check the power cables and confirm they are not properly connected.
If the speakers work fine , then it's all ok , but if they don't you need to replace the speakers by checking them with your friend's pc or any other audio output device.
Hope his helps.
May 11, 2011 | Computers & Internet
The speaker of my head phone is working and the mic is not working. the head phone is fine and i have also used another to check but the problem exist then also what to do?
I think you Mic is mute.
  • Go to control panel.
  • Click on Sounds and Audio Devices
  • Click on Advance Tab
  • See the Microphone is it mute.
  • If mute then uncheck the mute.
hope your problem will be solve
Mar 08, 2010 | Aardvark Direct Pro Q10 (bundle) External...
Windows 7 Audio Quadraphonic Not functioning well
Sounds like you are getting quad sound in the test process that checks them, yet when in windows media player or winamp (or whatever) your rear speakers aren't producing sound: Try setting your sound drivers to do something like "speaker fill" then you are set. I'm under the belief that stereo sounds aren't being matrixed into all 4 speakers.
Mar 25, 2009 | Computers & Internet
I have a dell pc and I am not getting sound form the insignia 2.0 speakers.
You did make sure that the speakers are plugged into the green audio connections, in the back of your computer, right? If so, try this, go to your control panel and double click Sounds and Audio Devices. Under speaker settings, go to Advanced and check to see if its set for desktop speakers. Also, in control panel, go to Sound Effects Manager and do a speaker test and see if they work. Hopefully this will help.
Jan 20, 2009 | Insignia 2.0 Speaker System (2-Piece)
Front Speakers don't work
restart your computer and let the system automatically detect your installed hardware. when it will detected set again the setting of sound and audio devices which founs in control panel into advanced audio properties. it will not work thus contact the online help which found at the box of the product.
Nov 04, 2007 | Creative Labs Inspire T7900 Computer...
Speakers not working, but cables all plugged in...
No drivers for your soundcard, this is a computer issue not a speaker issue, contact dell, if you can understand a word they say, ask them "I have Dimension (model number here), I need to know how to install my sound drivers", if you dont know how to do this.
Jun 21, 2006 | Dell A215 Computer Speakers
Intel Motherboard Logo
185 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
