Question about Haul Master Atv 2 Hitch Adapter With Loop Anchor Powder Coated New
Haul Master ATV 2 Hitch Adapter
What is it good for?
Can a hitch be installed on a 2003 cougar
Best solution for you call an RV shop and ask them. Most hitch shops will tell you sure you can do it. But can you you really? Ask the people that sell these things for a living they will what you can or can`t install for a hitch and what you can haul with it. Hope this helps
Mar 08, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
I am moving and I need to know if I can rent a u-haul trailer to hitch to my car.
yes, most authorised u-haul dealers can install a temporary hitch and light hookups
Nov 30, 2011 | 1998 Buick LeSabre
How much weight for factory rear bumper want 2 put 2" ball on to haul a trailer?
Bumper hitch ... probably 1500 #. It should be stamped in the bumper. If you want more, get a frame mounted class 2 hitch if you have a heavier trailer. Check your owners manual for GVWR (gross Vehicle Weight Rating) and DO NOT EXCEED IT! If you don't have a owners manual, check on the driver side door post for this rating. If you don't see it there, go to your auto parts supply place which sells these hitches, they can tell you everything you ever wanted to know about hitches.
Here is another resource you can check: http://hitchestogo.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=HTG&Product_Code=36244 It appears your vehicle is reated for a max Class II hitch. http://www.reesehitchestogo.com/trailer%20hitch/index.html
I hope you have found this information helpful. The courtest of a positive rating would be appreciated.
Thanks for your visit today.
Jan 30, 2011 | 2001 Chevrolet Blazer
How do i install a type lll trailer hitch considering the plastic pan that is part of the rear bumper?
suggest you try looking at u-haul for a drop hitch that will solve your rear bumper issue.they also do installation world wide if needed and they are the top experts in the hitch industry.i recommend them all the time.i can't say enough about how great those guys are about hitch problem solving.they sell hitches all over the world as well as rent moving trucks.they can still sell you the hitch that you need without installing it themselves,but unless you're a pro. i suggest that you have it done professionally. your life is at risk greatly when towing with a type3 hitch. hope this helps and thank you for choosing fixya.com
Jan 09, 2011 | 2000 Jeep Grand Cherokee
I have a 2003 Outback with factory installed hitch. The factory brake/turn light connector is set up for a U-Haul connector. U-Haul no longer uses that type of connector. I tried to splice in a standard...
You need a 3-2 wire converter. You could also install a plug and play connector such as the CURT 55370 if you have the wagon. If you are still having problems, click here to view an article i wrote on diagnosing wiring problems.
Jan 06, 2011 | 2006 Subaru Outback
Can I put a trailor hitch on my Elantra. I want to tow a car dolly (empty)
They do sell a small hitch for light loads, I believe it is 1000 lbs tug weight max, that can be put on your vehicle. The best place to look for a professional installation would be someplace like pep Boys or U-Haul. I say this because of the way your bumper is made you can't really attach to that with a hitch. The hitch unit has to be welded to or bolted up to the frame itself which takes special equipment.
Nov 15, 2010 | 2004 Hyundai Elantra
Does a 1994 buick centry come with a hitch and if not what is every thing that i need for a hitch
No it's doesn't come with a hitch. To put one on you'll need to know what capacity hitch you need, towing weight of what is to be towed. A wiring harness to connect to the vehicle's brake lights, taillights and turn signals. U-Haul sells and installs hitches.
May 09, 2010 | 1994 Buick Century
I have a master cycle and i need the hitch
I found something on amazon, here: Amazon com master cycle hitch. I hope I have helped. Cheers
Jul 14, 2009 | Cycling
Want to know the towing capacity for our truck
First off the 1997 F-250 HD with a 4.10 rear end will haul 14,900 lbs. The real question is do you have a receiver hitch or the rear bumper hitch. If you have the rear bumper hitch buy a receiver hitch that mounts to the frame a class 5 is usually put on these trucks. However a class 4 will work just fine for 6,000 lbs. The receiver hitch will have the capacity stated right on the hitch you just bend over and read it. It will give you two ratings one with weight distribution device and one without. You will be looking at the one without. That will fall somewhere between 6,000 and 12,000 lbs depending on the hitch manufacturer and the class. Hope this helps.
Mar 20, 2009 | 1997 Ford F250 SuperCab
Headlights high beam light inside stay on
Do you have an aftermarket hitch?? I have seen a lot of issues with people having U-HAUL hitch installed with the convertor box. Whell, when the convertor box is installed, u-haul uses scotch locks, which after a while causes all kinds of electrical issues. including head light issues. Also check the convertor box. It may be faulty. Nissan make a very nice harness for the truck. no splicing needed. There is a single connector behind the bumper on passenger side. Get harness. That is if you have the u-haul convertor. If you dont, I would be looking at the head lamp switch.
Jun 26, 2008 | 2001 Nissan Xterra
Haul Master Atv 2 Hitch Adapter With Loop Anchor Powder Coated New Logo
Top Haul Master Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Haul Master Boating Expert? Answer questions, earn points and help others
