Question about Plumbing
Tuscany faucet We purchases a single handle Tuscany (Kelso Model) faucet for a vessel sink. The cold water side works well however the hot water side does not work hardly at all. What suggestions are there to fix this problem. Water pressure is great.
3 Suggested Answers
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
motor1258
  • 6674 Answers
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Posted on Dec 29, 2009
I just installed a tuscany brookesville pulldown kitcken faucet. I cannot get any hot water. I checked the line and I have water to the connection. What do I do?
Hi Wilber- are you using the Watts brand "Floodsafe" auto-shutoff connectors for your hot & cold water supply lines?
Refer to the following link, please: http://www.watts.com/pages/whatsnew/floodsafe_connectors.asp
Feb 23, 2015 | Plumbing
How do I replace/repair the sprayer diverter valve in a Tuscany kitchen faucet?
Do you have a model # ? Normally the diverter will be exposed by removing the spout.
Dec 23, 2014 | Plumbing
My bathroom faucet drips. How do I repair?
there is a seal in the valve assembly that is warn they usually dell kits for it from a hardware or home depot store
Sep 11, 2014 | Plumbing
Where I can find replacement handles for a Tuscany bath faucet?
Bathroom fittings and accessories is the ultimate destination where you can get best quality replacement handles for a Tuscany bath fauce.
Apr 14, 2013 | Home
The hot and cold are reversed on our single handle shower (no tub faucet -- shower only)
Hot on left.
Cold on right.
Some single handle faucets have bleed-over where both hot and cold enter mixing valve each time handle is turned on, even when faucet calls for just cold or just hot.
Otherwise maybe a do-it-yourself plumber got pipes backwards... or maybe the tub used to be on other side of wall, and tub was moved during remodeling but pipes were not changed.
To fix problem:
First of all, turn off shower faucet. Turn on Hot at sink and put ear against shower faucet listening for sound of water flowing through the mixing valve.
If mixing valve is working fine, you need to open wall and investigate more.
For example if you have access door, reach in and feel which pipe is hot.
Pipes might need to be reversed if problem comes up in home inspection, otherwise the problem will not harm anything.
Feb 19, 2011 | Price Pfister Plumbing
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Apr 01, 2010 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
Moen single handle kitchen faucet, Hot water and
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Plumbing Logo
60 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
