Sony tv wont turn on
Tv clicks and hss like its going to come on but does not. after several more attempts and about hour or so it finally turns on
This problem usually caused by a leak or bulging capacitors on the power supply section.some of this are caused by a 250 volts capacitor 2.2 uf it comes in a very small packge.
Posted on Nov 22, 2013
Alleluia
  • 69 Answers
SOURCE: sony triniton KV- XG29M30 WONT TURN ON
I had a similar problem a few years back . I purchased a new on/off switch from Sony and that seemed to fix things.
Alleluia
Posted on Jan 06, 2008
  • 4234 Answers
SOURCE: TV Sony KV-29F1E turn-on failure, red standby LED flashes (starts after 10-20 attempts)
When the set ends up flashing the LED, it should be a repeatable count. Can you please report that count here? Also, since the set eventually works, I'd suspect a bad connection or a part that has changed value over time. The blink code will help to narrow down the offending circuit.
Dan
Posted on May 12, 2008
sharptech1
  • 29 Answers
SOURCE: Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Posted on Jan 12, 2009
marketex
  • 371 Answers
SOURCE: Sony TV works briefly then turns off by itself makes a click
It's serviceable, and will need service on either the thermistor that is turning the set off, and/or the parts of the circuit that are overheating the thermistor.
Posted on May 10, 2009
Spencerjt
  • 17 Answers
SOURCE: sony trinitron not working
The power supply has failed which are very expense and your better off Getting a new T.V.
Posted on May 23, 2009
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Sony trinitron not working
May 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 46" lcd turns off by itself and will not power up again.
Sony TVs come with a one year warranty on parts and labor. Call Sony at 1-800-222-SONY They will find a local company to service this product.
These TVs have a self-diagnostic screen that a tech can access to help solve the problem. Your problem could be any number of things including the fan(s) stopping, the ballast board failing, Q-box issue or none of the above.
michtech
Feb 19, 2009 | Sony Televison & Video
if your tv unit is still under warranty, first you better bring it back again to the store you just bought it for warranty purposes, your tv has an internal problem, maybe manufacturer defect. Usually the cause of that is a shorted electronics component, say for ex, a mosfet transistor that is located at the power section, or maybe a capacitor that is leaky, and also an open resistor. if you don't know how to troubleshoot this problem, you better have your tv unit repaired by a professional tv technician.
Good luck
Jan 22, 2009 | Sony KDL-46S4100 46 in. LCD TV
30 YR SERVICE TECH.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I have spent about 4 hours tonight researching several tech sites and the Sony service manual for the same problem with my Sony KV-32HS510 unit. I was able to download the manual from a website http://www.eserviceinfo.com/downloadsm/31649/Sony_KV-32HS510.html and a TV Repair training lecture paper at http://www.repairfaq.org/sam/tvfaq.htm#tvhvp .
These TV sets have a safety feature where it will shut back down if a high voltage is indicated. Unfortunately, the electronics for these safety features are not very reliable and give false indication. Letting the unit sit off lets the capacitors leak voltage as well as cool off. These two factor help with the unit not falsely indicating a high voltage condition.
The D Board seems to be the most common failure component, but a 6 times flash could be an overcurrent/voltage failure from the A, B, or M boards. A 7 times flash is a Horizontal Deflection Stopped error with no additional information given in the manual for a fix. Again, in most blogs, the D Board seemed to the source of the failures.
A refurbished D Board part no. A1300319A can be bought for around $200 with a new board at $550 per the www.partstore.com site. Then add $100-$200 for an actual TV service technician and you have a repair bill approaching the costs for a new flatscreen TV.
Some tech types posted that they have actually repaired their boards by replacing individual components for around $40. You may find a service shop that can do the same component level repair at the $100-$150 level cost. It turns out that the closest authorized Sony repair shop is 2-1/2 hours away from us. Good luck finding someone close by.
We were able to get our TV to come back on after dozens of attempts and plan to leave it on until it dies all together. I may attempt my own D Board replacement when the time comes.
Dec 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KV-32XBR96S Wont power on,Just makes clicking sound
I have the same problem with the power button clicking on and off was there a solution? Is it worth fixing?
Nov 30, 2008 | Televison & Video
Spark Gap Lamp Driver Problem? Sony LCD TV?
Lamp driver error 5 times - Lamp driver is faulty. The symptom will be no picture or sound . Repalce the lamp driver.
Apr 27, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Sony triniton KV- XG29M30 WONT TURN ON
Alleluia
Jan 05, 2008 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
