Rca 42la45rq stuck on one channel and volume runs up and down by itself
  • 927 Answers
SOURCE: RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Posted on Jun 01, 2008
  • 184 Answers
SOURCE: MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Posted on Feb 17, 2009
SOURCE: volume turns down by itself
Its the buttons on the tv, they need to be replaced, or replace the whole key pad on the tv. that should fix ur problem
Posted on Mar 28, 2009
SOURCE: rca turns itself off and on and scans thru all the channels
I have an easier solution, First I want to thank those who posted the solution that the problem is on the small switch board mounted right behind the switches under the picture tube. I figured that might be where the problem was but it's better to to see it confirmed. I thought the problem was more complex like maybe an IC chip got zapped or something but there are none on that board. Only 6 switches, the infared sensor, 1 capacitor and some resistors. I am convinced that in my case at least the problem is caused by humidity. It happened last year constantly durring humid weather in the summer and only a couple of times over the winter when the air is dry and cooler. I did figure an easier way to disconnect all the switches without unsoldering. After you remove the board, flip it over to the solder side and see where the wires connect. You will see them labled GND - KEY - +5 v - LED and IR. The one you want is labled KEY. You will see on the other side this wire is second from the end . Just separate the wires a bit and cut it. That's it. Just be sure it is the one marked KEY. This wire goes thru a series of resistors and the switches and nothing else. Just cut that one wire and put a piece of tape over the cut ends and thats it. it's a lot easier then unsoldering all 6 switches. And if you do decide at some point later to replace the switches, it's easy to resolder the wires and tape it. I did it this way and my TV is working perfect. I was done in ten minutes. You can only control the TV with the remote but so what, thats all we use 95% of the time anyway. I hope this helped you.
Posted on Sep 05, 2009
Slinteriors
  • 8617 Answers
SOURCE: I HAVE A RCA D52W23 52 in. Rear Projection
the small signal board usually causes those symptoms.
Posted on Jan 14, 2010
Testimonial: "thank you i fixed this problums front penal button clean with some spry and its work,,,"
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
RCA 42" 42LA45RQ
Check and replace its main power regulator board as card basis.
Jul 30, 2013 | Televison & Video
Rca L40FHD41is stuck on menu,cant change input or volume . how to reset the tv???
Unplug the TV for a few minutes it should reset itself.
Make sure the menu button is not stuck, if it is try cleaning the button.
www.aaatvservice.com
Jan 28, 2012 | RCA Televison & Video
Volume turns down by itself
Mar 17, 2009 | RCA F36650 36" TV
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
My rca t.v. wont stop turning itself on and off.
check to see if the front control buttons are stuck,if not possible power supply or eeprom ic.
Mar 19, 2008 | Televison & Video
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
Rca 24t511t 24" issues
CHANGE ALL SWITHES ON CONTROL PANEL, POWER, BOTH VOLUME UP AND DOWN AND CHANNEL UP AND DOWN. THEY ARE LEAKY
Jan 13, 2008 | RCA 24V511T 24" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
