Question about Durabrand DUR7 Portable DVD Player
Li-ion battery started swelling when charged
Battery swelled when charging
  • 3 Answers
SOURCE: Durabrand bat-09 battery not holding charge
I had the same problem. I wrote to Walmart.com corporate. The contact us section. They called my local store who replaced my machine with a magnavox.
Posted on Dec 05, 2008
  • 42 Answers
SOURCE: I HAVE A PROBLEM WITH PORTABLE DVD BATTERY WHAT
This model of DVD Player is made primarily for Walmart Stores so am Assuming you bought it there. Battery Swelling is an acid combustion issue, meaning they over-expired or over charged. Don't leave these charged for too long. Other than recommending to get the replacement that is mentioned in the original Users Manual that came with it, it's quite difficult to get a replacement. I have added a site below for walmart purchases that may be compatible with your unit.
http://www.walmart.com/catalog/product.do?product_id=9863775
Unfortunately, without getting an exact genuine replacement, there is a down side to the Universal Battery. They claim to hold up to 11 hrs, but the average usage is about 5 hrs constant use. So you figure instead of 4 full length movies maybe 5, you might get about 2-3 movies if you're lucky. Trial and error and user results vary obviously.
And you may wish to check with Walmart. I believe this unit had a recall on it due to faulty wiring and or battery issues that cause a fire hazard. Silver Durabrand DVD Players as well as Purple and Pink ones were recalled. I would take it back if that is where you bought it and ask them about the recall. Or check with www.cpsc.gov to see any updated info.
Wish you luck.
Posted on Mar 09, 2011
gopakumarg43
  • 74136 Answers
SOURCE: I need a replacement battery for durabrand portable dvd player model pdb 702 . a li-ion polymer recchargeble battery pack
Hello
Li-Ion batteries can be bought from most of the electronic spare part selling shops at your town. Check its specifications, ie, voltage, amperage, size etc, before buying a new one.
Posted on Feb 28, 2012
tunerprobe94
  • 26 Answers
SOURCE: Where can I buy a Li-iON polymer battery pack Model:BAT-05 7.4v 2600ma Thank you.
try going to the companies website or either try ebay. ebay nay be cheaper!
Posted on May 24, 2012
ercupa190
  • 12223 Answers
SOURCE: Where can i buy a replacement battery durabrand li-ion model bat-09 7.4 v 2800mah
you can find in radio shack or computer stores or electronic suppliers parts.
God bless you
Posted on Jul 13, 2012
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
Battery swelling , seems like over charging
IF IT SAT OVER THE WINTER, IT MAY HAVE FROZEN AND THAT WOULD MAKE IT SWELL.
IF IT DID NOT FREEZE, THEN IT WAS OVER CHARGED. IF IT STILL RUNS, THE SWELLING WILL NOT AFFECT THE OPERATION.
Feb 21, 2011 | 1990 Yamaha XT 600 E
How many hours we should charge the battery fist time Nokia-2700
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Oct 07, 2010 | Nokia N70 Cellular Phone
I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
http://www.bobatkins.com/photography/digital/hp707.html
Aug 08, 2010 | HP Photosmart R707 Digital Camera
Battery has stoped working and has swelled in
This is because the life of battery is finished.This occurs due to prolonged charging.
Please replace the battery.DONOT charge anymore there may cause explosion of the battery.
Thanx
Jul 27, 2010 | GPX PDL805 Portable DVD Player
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Have 24v sds drill older type the one with the charging lights on 2 of the batteries will no longer charge just go to red on charger unit can they fixed
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
Oct 12, 2009 | Bosch Drills
Sony DCR-VX1000E batteries
Li-Ion batteries cannot be charged efficiently with power supplies or NiCad chargers, they need a pulse charger dedicated to Li-Ion batteries. Also, there is a danger in charging with other sources as Li-Ion batts. will catch fire or explode if not charged properly. Please get a charger that is made for those batteries
Jun 19, 2008 | Sony Handycam CCD-TRV37 Camcorder
My battery swell
Hi, Battery is calculated in Cycles and One Cycle is One charging & discharging. In ur case probly u might have used ur 300 Cycles. Most of the people do a mistake of keeping charging for whole of Night but when u talk about the cell phone if u keep in charging for the whole night unnessary Cycles are getting wasted. Mobile charge has a funda like it charges and over a time automatically it discharges as well. so don't keep it in Over night charging. U need to replace the battery. Else u will not get a perfect back up. Madhu AVN
Jan 28, 2008 | Sony Ericsson K310i Cellular Phone
Durabrand DUR7 Portable DVD Player Logo
20 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
