Question about Polaris 3900 Sport Pool Cleaner ()
Polaris 3900 doing wheel stands - Polaris 3900 Sport Pool Cleaner ()
    Top Expert:
  • Polaris Master
  • 5,080 Answers
Adjust thruster to 11:00
Posted on May 22, 2016
5 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: The wheels on my Polaris
There are a couple things that you should check with these pool cleaners if the wheels are functioning properly. Check the filter screen in the in-line filter assembly and clean if necessary.Make sure that you do not have any debris or obstructions that could be halting wheel function. Even though you seem to have plenty of water, check the RPM and make sure they are between 28 and 32.
Posted on Mar 17, 2011
jharwell668
  • 640 Answers
SOURCE: My polaris 3900 moves across
Check your wheel RPM. If the pool cleaners RPM is over 32, reduce the water flow so that the cleaner makes proper contact with the pool's surface. Verify the back-up valve is cycling. Lift the valve out of
the water and watch the jet. It should come on and go off. You might also need to adjust your thrust jet if it is causing the cleaner to lean too far to one side.
jharwell668
  • 640 Answers
SOURCE: I purchased a Polaris 3900 on 6/2/2010 and have
First, make sure that the velcro closure on your pool cleaners bag is sealed tightly. If the velcro is coming lose, it could be the problem. Next, make sure that your wheels are operating at the proper RPM. Too little RPM could cause the pool cleaner to be sluggish and not create the proper tension to keep the bag floating. It should be between 30 and 36. If it is running at less than 30 RPM, there are few things that you can do to fix it. If an adjustable valve is installed on the cleaner line, open it completely so water can flow freely to the cleaner. Check the filter screen in the in-line filter
for debris that restricts water flow and clean if necessary. Also clean the skimmer, filter, and pump baskets. Check the hoses, connections and swivels for leaks that cause loss of water pressure. Finally, if none of these solutions work, remove the blue restrictor disk from the UFW.
Posted on Mar 30, 2011
SOURCE: My Polaris 3900 Sport Pool
I had a similar issue. When I lifted the unit out of the water while it was operating only the single wheel was rotating. I turned it off and removed the bag and hose. I flipped it over on a workbench and unscrewed the three recessing screws securing the base plate. Once the plate was removed I noticed the metal chain driving the two wheels had come off on the far side of the inner sprocket. I worked the chain back onto the sprocket and tested it by rotating the single wheel and verifying the other two wheels rotated. After reassembly I put the unit back in the pool and it drove straight and high on the sides. Hope this helps someone :-)
Posted on Nov 25, 2012
Sport 3900 is doing wheelies will not stay level to clean
1. Check the wheel RPM. If not in the 30-36 RPM range, refer to the manual for adjusting the wheel RPM.
2. Adjust the thrust jet downward.
3. Verify the backup valve is cycling. Lift the valve out of the water and watch the jet. It should come on and go off.
4. Check for water inside the head float.
5. Empty the filter bag.
You can download the 3900 Manual from the Polaris site
http://www.polarispool.com/Pressure/Polaris-3900.aspx
It will show you how to check the wheel rpm and how to adjust the thrust jet and check and adjust the float.
Jul 06, 2014 | Polaris 3900 Sport Pool Cleaner ()
Polaris 3900 wheels don't turn
if good pressure at wall and filter is ok check inside to see if hoses are off or belt broken
Dec 23, 2012 | Polaris 3900 Sport Pool Cleaner ()
Polaris 3900 wheels won't turn
check inside see if belts or hoses came off
Oct 20, 2012 | Polaris 3900 Sport Pool Cleaner ()
Wheels not turning on polaris 3900
if water pressure at hose check inside to see if hoses or belts came off
Sep 30, 2012 | Polaris 3900 Sport Pool Cleaner ()
My polaris 3900 is not moving at all
if pressure is ok at wall check inside to see if hoses or belts or gears on wheels ok
May 26, 2012 | Polaris 3900 Sport Pool Cleaner ()
The wheels on my Polaris 3900 don't move. Plenty of water coming thru the thrust and the tail wags. When I move the wheels manually they all move together.
Jan 30, 2011 | Polaris 3900 Sport Pool Cleaner ()
Polaris 3900 Sport Pool Cleaner () Logo
47 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
