Question about Ryobi Js550l Jig Saws
What blades are used in a Ryobi JS550L jigsaw
Bought the unit used and it did not come with a blade.
SOURCE: changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Posted on Feb 09, 2009
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
  • 13 Answers
SOURCE: loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Posted on Jun 05, 2009
  • 5603 Answers
SOURCE: ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Posted on Sep 28, 2009
Testimonial: "Thanks; that's the advice I got when I tracked down the number to call Ryobi. However, it doesn't seem to be working. Now sure what is wrong :("
puertobori
  • 7733 Answers
SOURCE: Trying to change blade in Ryobi P520 Jigsaw
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
Posted on Nov 04, 2010
Ks656pe how do i change the blade? i don't have any instruction. Please
Quick-Change Blade Mechanism
Higher-end models, such as the Linefinder Orbital Jigsaw, feature a clamping lever to hold the saw blade. To change a blade, switch off the jigsaw, unplug it, and let the used blade cool down. Pull up the saw-blade locking lever and let the used blade fall out with a slight shake. Turn the jigsaw upside down. Hold the fresh blade with its teeth forward; insert the blade shank into the blade holder as deeply as it will go. Release the lever and wiggle the blade to confirm that it's snugly in place. For models with rollers, such as the Accu-Trak, nestle the blade against the rollers.
Clamp or Hex Screws
Loosen the pair of screws -- on the front of the mechanism of models such as the single-speed jigsaw -- a full turn counterclockwise with a flathead screwdriver, but do not remove them. The used blade will fall out. Insert the new blade fully into the clamp. Lightly tighten each screw alternately and then fully. On older models, you may find a single hex screw on the side of the blade. Loosen this enough to remove the blade, and then insert a new blade carefully so the teeth face forward. Retighten the screw.
Oct 03, 2017 | Saws
How to change blade on a Chicago jigsaw
Harbor Freight Chicago Electric Jig Saw - Review - YouTube
? 2:21
www.youtube.com/watch?v=lSh0M4WIJTk
Dec 13, 2013 - Uploaded by AdamDIY
Chicago Electric - Orbital Jigsaw 92772 They change the design over time but some of the key flaws tend to ...
jigsaw from hell - chicago (electric?) brand - DoItYourself.com ...
www.doityourself.com/.../445560-jigsaw-hell-chicago-electric-brand.ht...
Mar 9, 2011 - Most blades either have a hole in the shank or the shank is shaped like a .... A brand new one is only about $25 and no tools for blade changes.
Oct 22, 2015 | Saws
What type of blade do I need for a jigsaw ryobi js500qeo
Any type of jig saw blade will work, the are universal....
Feb 25, 2015 | Ryobi Saws
How to fit blade in performer 350w jigsaw
There is a blade release that you have to push up while inserting blade. If this isn't the problem, there are many types of blades for different jigsaws. You need the one for your brand. Take an old blade with you when you purchase. Good luck
Oct 18, 2014 | Saws
Extracting broken blade not sticking out of blade holder
Spray with WD 40 and insert Needle nosed pliers to grab and pull it.
Nov 30, 2013 | Ryobi Js550l Jig Saws
How to put blade in jigsaw
There should be a setscrew of some kind that holds the blade in place. Maybe like a allen or torquse bit type.
Jun 13, 2012 | Ryobi EJ-600 Jigsaw 600 Watt - RYBEJ600
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
My original blade broke so i bought a new blade from wickes 10tpi now when i use it i saw on the line i have marked but on the other side of the 2x2 it is about quarter to hallf inch out how can i make...
There are good blades and there are cheap blades. Good blades are straighter but less tolerant of poor technique and so tend to break, cheap blades can and do bend far more. You can keep the blade straighter by not forcing the blade through the work and allowing it to cut at it's own rate and by experimenting with the speed settings on the jigsaw. It also helps if you pick the correct blade for the job: 10tpi is a bit too coarse for ripping a timber batten along the grain but fine for rough cutting chipboard. Also, it's difficult to keep the foot of the jigsaw absolutely level on 2x2 which adds to your problems.
Aug 15, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Blade wander
a jigsaw is for cutting wavy lines if u want a straight cut use a rip saw with fine blade but you still can use a jigsaw must have sharp blade there is a blade u can get now from screwfix with a triangle spine on the back off the blade to prevent it twisting works fine (also do not push hard on the powertool let the blade do the cutting less likely to wander hope this is of help
May 30, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Ryobi Js550l Jig Saws Logo
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
