Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Cabrio Pressure Switch - Whirlpool Cabrio WTW6600SBT Top Load Washer
Fh code cabrio
Check the connection between The inlet valve, pressure switch, drain pump, flow meter, and connection to the ccu.
Apr 25, 2014 | Whirlpool WTW6400SW Cabrio Washer
What does F32 mean
f32 is usual pressure switch failure
Feb 09, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool front loader cabrio stopped working with 12 minutes left in the cycle. The Ld code is flashing and I don't know how to fix it so that the load will spin and drain. How do I fix this...
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
New whirlpool wtw6500ww cabrio washer has overflowed with water every load I ran today. What am I doing wrong? It ran over with every size load.
There is a clear hose that goes from the tub to the pressure sensor on the control board. It tells the washer when to shut off the water. It is probably either punctured or disconnected, or the pressure switch needs to be replaced. If it's new its probably still under warranty and you should have whirlpool fix it.
Jan 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio no longer adjusts water level according to load size. It fills to the max each time. How to fix?
problem most probably in clogged pressure hose leading to pressure switch or bad pressure/level switch itself.  you can try cleaning the hose by simply blowing into it after disconnecting it from the pressure switch.  a simple fix but if clogged, it usually works.
Aug 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld code
taking too long to drain,there is somthing in the drain pump intake or the drain hose is kinked. there could be somthing in the pressure switch hose makeing it think it still has water in it
Dec 08, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
High oil pressure in vw cabrio 1996
MY 1996 VW CABRIO HAS A HIGH OIL PRESSURE THE SWITCH IS BLOING OFF AND LOOSING OIL ANY IDEA IS IT JUST A REPLACE THE PART KIND OF JOB.. THANK YOU
Sep 25, 2009 | 1988 Volkswagen Cabriolet
Whirlpool Washer-Cabrio. It won't run and time
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^@#$%
Sep 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio (WTW6600SW1) drains completely then Ld error!
I have a call with the same problem. Pumps all the water out but still flashes LD. Should be the board, The electronic pressure switch is built in to the board. Make sure the pressure chamber on the back right side is not cloged
Aug 10, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
