Question about Seaward Princess Model 3247 3-Burner Electric Stove
Seaward 3247 burner not heating up - Seaward Princess Model 3247 3-Burner Electric Stove
NEED KNOB PART #80421
http://www.suremarineservice.com/80421.aspx
Mar 05, 2013 | Seaward Princess Model 2276, 2 burner...
Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
Mar 21, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
GE profile performance electric cook top is not producing enough heat in the front burners.
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
Kenmore Electric Counter Unit 43421
You are right it is the infinate heat control. This has no thermostat. It works by letting the burner cycle on for longer periods of time on the higher settings on high it is on constantly. The contacts are probably fused inside This part shouldn't be more than $25.
May 27, 2008 | Kenmore 30 in.44062 / 44069 / 44064...
Stove burner/ maytag double oven
did you use ajax or any cleanser that might leave a powdery residue is any of the air/gas holes clogged is the burner clogged internally, can you put anotheer burner in that place to see if it is the burner check it out.
Dec 28, 2007 | Cooktops
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Burners are not fully heating out to the end
Either the elements are going out or the controlls for the burners are getting croded contacts. Best bet would be to replace both and go for another 7 years :-)
Sep 10, 2007 | Jenn-Air JED8430 Electric Cooktop
Seaward Princess Model 3247 3-Burner Electric Stove Logo
14 people viewed this question
Top Seaward Cooktops Experts
Paul Carew
Are you a Seaward Cooktop Expert? Answer questions, earn points and help others
