Question about Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan
How to stop the humming in my hunter 21871
How do I stop the humming coming from my hunter (21871) ceiling fan?
  • 59 Answers
SOURCE: Motor Hum
check your grounds and all other connections. remote wiring has to be precise. somes times not for the do it your selfer. all the labor youve encountered somes the cheap can turn out to be very expensive.
Posted on Apr 26, 2009
SOURCE: we have a hunter type 2 ceiling fan installed on a bedroom ceilin
Okay. Turn off circuit breaker. Take the bottom off the fan. Mark how the wires are connected. Remove switch by unscrewing the sleeve you mentioned. Take the switch to Home Depot (or the like) -- buy a replacement.
If you have to turn the breaker back on during this process, make sure you have a wire nut over the end of each of the loose wires you disconnected from the switch.
After you take the switch out, you'll know how to reinstall it, so I won't go thru that.
Charlie
Posted on May 12, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
  • 1114 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Posted on Jul 21, 2009
  • 163 Answers
SOURCE: Hunter Sonic Ceiling fan comes on by itself
is it your grage door opener that could be doing it
Posted on Jul 26, 2009
I broke a fan blade. Where can I buy a replacement?
hi mebes76...
Go to this webpage and move your cuser over "Support"...in the drop down window go to "Manuals & Parts Guide.
Find your part, order your part directly from Hunter.
Please take time to rate me
http://www.hunterfan.com/
Aug 05, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
We purchased the Hunter Ceiling fan over a year ago and it has worked fine up until a couple of weeks ago. When we turn on the light it just continuously blinks on and off.
there is a watt governor, or black box for the lights to cut down on wattage or energy use. you can remove the black box for the lighting, and wire it directly to the main wires. white wire to white wire, and black wire to red wire. black and red are always a hot wire and white is a neutral wire. the part number on black box should be 98480-02. this should stop the lights from blinking. have a good day !
May 28, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
How does the receiver of the Hunter model 21871 ceiling fan attach to the canopy? There are two things on the receiver that seem as though they should connect to the canopy with slots but no slots in the...
if you look at the mount bracket where the ball of the fan fits in to it should fit right above the ball in the mount bracket and if it can fit loose in the canopy thats ok to just long as ou can get the bell housing back up
Jan 23, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Bought a display hunter 20171 Ergonomics C Fan. The wires were cut short, remote control receiver not included.
have no choice but to buy the original receiver through hunter - not a replacement from HD or Lowes - it will not work.
Nov 27, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
The ceiling fan do not occilate the light turn on but the other does not work propperly
mcdevito75 here, Both the fan and lights work off the wall switch, for the fan to work there is also a pull chain close to the ceiling on the fan shroud you have to pull that chain to get the fan going and 1--2 more times for various speeds. If by chance the fan is brand new, reove the blades and check for stops in the fan motor, right where the blades hook up, these are in place from the factory and have to be removed for the fan to work, they pull right out.
Jul 27, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Mar 02, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Remote control fan
I had the same problem and I thnk Hunter Fan knows about it....I just called Hunter Tecnical Support at 901-745-9222 and they sent me a new White circular receiver which goes inside of the canopy and it worked fine after installing the receiver....
Mar 14, 2008 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan Logo
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
