Question about Snom 720 VoIP Phone
Crackling sound on call - Snom 720 VoIP Phone
Why is the sound crackling on my acer aspie 5935g laptop
A crackling sound maybe caused by a defective speaker, try to replace it to eliminate the crackling sound.
Nov 08, 2010 | Acer Computers & Internet
Crackling sound
Have you tried some headphones directly into the headphones socket? Does the sound still crackle? Usually 'crackle' is associated with dodgy leads and you will be able to hear the lead responding to movement by crackling more, a hissy sound often means that there is a fault with the socket and sometimes removing and reconnecting the jack into the socket a few times will help this. If it sounds like hiss with little pops it's usually electrical interference and could mean a bad earthing in the circuit somewhere
Jun 06, 2010 | Dell (8H390) Sound Card
I have a crackling speaker on the left port of the bass box
The crackling sound on the left port of the bass box, indicates vibrating foreign matters inside it. Just open the box and clear it up. Put the sounds on. Listen if the crackling sound is audible. If the result is ok, then, close the box, and everything is alright..
However, if the result is otherwise, then, it is due to a defective speaker that needs to be replaced.
Nov 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
My ipod crackles and my hearing seems to be getting damaged
Id say you should go see a doctor. But for now id say that you should do your best to not listen to it for a while as it can affect hearing. try to use full on speakers if you can. On you tube there are a few Sub-Woofer sound tests you can do. Try playing one (low volume) and repeat. (not a song one)
http://www.teenbuzz.org/ also to hear which frequencies are out of range to you click here. ( click the second icon on the list further down the page)
But yeah go see a doctor. Perhaps some ear drops.
Sep 01, 2009 | Apple iPod touch
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
Crackling Sound
Hello there
The issue that you are descibing sound it a bad small signal board which needs to be taken to thr repair shop.
Jun 05, 2008 | Hitachi 55HDS69 55 in. Plasma Television
TV is crackling
From the speakers or from the inside of the unit. On all modes, eg. normal tv + digibox/scart input???
Apr 05, 2008 | Televison & Video
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
Crackling from surrond sound
I have a SONY home theater4.gif system, HT-C800DP, there is a crackling sound when playing DVDs - it is almost as if the unit overheats. Is there any solution to this? Sometimes I cannot even finish a DVD as the noise gets very loud.
Thanks,
Cindy
Aug 14, 2006 | Sony HTD-C800DP System
Snom 720 VoIP Phone Logo
29 people viewed this question
Top Snom Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Snom Radio Communication Expert? Answer questions, earn points and help others
