Question about Masterbuilt Electric Digital Smoker
Smoker keeps tripping breaker and won't come on
My smoker got wet and now when I try to use it it trips the breaker, can I fix this problem?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Electric smoker is now tripping GFCI breaker
GFCI breaker tend to wearout and become more sensitive after time and use. Motor loads are especially hard on them. Also resistance loads such as heating elements. Your smoker may be pulling a bit more electric than it used too.
Check the power draw of the smoker when operating, if it is high then fuigure out why. It it is normal then replace the braker. Use a regular breaker if the GFCI is not required, or run a cord from an outlet that is not on a GFCI breaker.
Heatman101
Posted on Jan 24, 2010
I have a master built 30 smoker, after 5 minutes in keeps tripping the gci /breaker. Sorry, I have used it on the same outlet numerous times without any problems
the ground circuit interrupter is supposed to trip if a short or condition which causes the power to quickly go to ground. make sure your machine aint shorted out and is properly grounded by checking each prong from power supply cord to frame of the smoker. if no shorts then the GCI must be getting weak and prematurely tripping on its own or simply not rated for your appliance.
Jun 29, 2017 | Dryers
Cajun injector electric smoker stopped working
Check for power at your outlet; a tripped GFI or a tripped breaker in your panel box may be the cause if the outlet is dead. If the outlet is good then you know it is the electric smoker.
Nov 27, 2014 | Cajun Injector Double-Door Xl Electric...
NEVER HAD A BREAKER TRIPPING PROBLEM TILL IT RAINED FOR A WEEK! i REPLACED BREAKER AND IT STILL TRIPPS
Hi Jesse,
I believe the rating of breaker for the shop is not correct. Power use in the shop is more than the capacity the breaker was designed to handle. Try switching off some appliances in the shop and see what happens. You will then investigate further to resolve your issue.
Sep 26, 2014 | Electrical Supplies
Eeaf smoker keeps tripping off
Hi sally mako...
Make sure your breaker is strong enough to handle the ampreage draw of the smoker element.
Try a different receptical with a known larger breaker...
If still kicks the breaker, then remove the electric plug from the receptical and check all connections on the element and controls to make sure they are not corroded or broken and shorting out.
Please take time to rate me
Sep 24, 2011 | Masterbuilt 20070106 Electric Smoker
Grill will not turn on
I assume you are referring to the auger motor. If so, have you checked the electric receptacle the g=auger motor is plugged into? Plug another electric appliance, like a lamp into the receptacle to see if the lamp works. If not, look for a tripped circuit breaker in your home's breaker panel. If one is tripped, make sure nothing is plugged into the offending receptacle and reset the breaker. Plug the auger motor back in to see if the breaker trips again. If does, there's an electrical issue with the auger motor or the cord.
If none of the above is the problem, i have included a link to Traeger Industries website. There you can find and download the Owners Manual for your Grill-Smoker, which also has a Trouble Shooting Section.
http://www.traegergrills.com/
Feb 21, 2011 | Traeger Industries BBQ070 All-in-One Grill...
The auger on my 9 yr old grill has stopped and my family is not happy! I do not have a Mr Fix-it husband so am on my own. Any suggestions?
Make sure that there electric power to the auger motor. If it's plugged into an exterior wall outlet, unplug it and plug in another electric device (like a lamp) to make sure that outlet still works. If it doesn't, go to your home's Circuit Breaker Panel and check for a tripped breaker. If you find one that's tripped, reset it and try plugging in the auger motor and turn it on. If it starts working then suddenly stops, it probably tripped the circuit breaker again. That would indicate one of three things: The cord from the auger motor may be bad; the auger motor itself may be shorting out; the circuit breaker may be failing. If it's the receptacle or the circuit breaker, I'd advise you contacting an electrician to have them check and replace it. for the Auger Motor, go to Traeger's website home page and look for Trouble Shooting or Customer Support. Better safe, than sorry.
Hope this helps solve your problem.
Feb 08, 2011 | Traeger Industries BBQ075 All-in-One Grill...
My smoker keeps tripping my ground fault receptacle. I plugged in other items and i had no problem with tripping the ground fault. I also had to change the female connector going to the heating element.
If nothing else is tripping your GFCI, then there is a short somewhere in the wiring of the smoker. Check the female connector you had to replace, as well as that particular to see if you can detect any melting of the insulation or a bad connection of the other end.
Typically, electric smokers use high heat resistor wiring. So, something in the wiring is not like it should be. Or it may be the heating element itself. If it's still under warranty contact the manufactirer.
Feb 06, 2011 | Masterbuilt 20070106 Electric Smoker
Heatman101
Jan 24, 2010 | Masterbuilt 20070106 Electric Smoker
My electric smoker keeps tripping breakers
My Brinkmann 810-7080-4 Gourmet Electric Smoker was tripping my GFI after it sat for the winter. Would heat for about 3 minutes then trip the GFI. would keep tripping GFI until it cooled down and once again would trip after about 3 minutes.
--SOLVED: took 00 steel wool and olive oil to the heating element and removed what looked like a green fungus. Element is working fine now, not tripping the GFI and will run a full four hours for smoking!
Hope this helps save someone some money in purchasing a new heating element ($40).
Nov 26, 2009 | Brinkmann Smoke' n Grill Electric Double...
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
Masterbuilt Electric Digital Smoker Logo
32 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
