Question about Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
How do I remove the spout on Moen 7065
The spout is leaking and allen srew won't stay tightened
  • 659 Answers
SOURCE: Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Posted on Apr 05, 2009
  • 82 Answers
SOURCE: I have a slow leak coming from the spout
ooops, didn't mean for that to be a request, sorry...It was a solution. Although, if you dont want to deal with Moen, you can get one at your local plumbing suplly store. I recommend taking the old one with you (make sure you shut the water off first!). Again, good luck
Posted on Sep 03, 2009
  • 129 Answers
SOURCE: moen 87135c - cant take apart
On handle of faucet you will see a red/blue plug button, under that is a set screw. loosen and this will allow you to remove handle.
Posted on Oct 04, 2009
Testimonial: "thanks - i saw it there but didn't see the set screw - now if i can only find the right size allen wrench -standard US doesn't fit!"
  • 377 Answers
SOURCE: I have a Moen Faucet
If the allen screw will not turn I would put an allen wrench into it and lightly tap it a few times with a hammer, the smaller the better. If the allen screw is stripped I would get a set of easy outs from the Home Depot or other store and use the smallest one to ease the screw out. An easy out works in reverse to the threads in order to get the screw to back out of the hole.
Posted on Sep 12, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: i have a loose spout
Sorry to read about your problem, I hope this helps you out.
you have to go underneath the counter... look up and you will see what bolts are loose
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Posted on Dec 25, 2010
How to remove the screw under the plug button on the moen 7065
Easy! Simply turn the water off, pry the cover loose, raise the handle until the screw head is centered in the access hole, find the right size allen wrench and remove the screw, then the handle can be removed.
Jun 15, 2014 | Moen 7560C Extensa Kitchen Faucet
How to tighten swivel spout of moen kitchen faucet
pop the cover off the top of the spout tighten the screw underneath and replace the cap.
May 11, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
How to fix Moen Banbury model 87690SRS kitchen faucet ?
There is no way to tighten spout from top of sink. If you slide in cabinet and look up at the bottom of the faucet (spout ) you will see a nut on the threaded shaft of the spout hanging below in cabinet. With a basin wrench, kind of like a spring loaded pair of channel locks with a long extension arm and t-handle, you get it around the nut and tighten it clock wise on the shaft. You may have to disconnect the faucet valve ( handle part of faucet) from the bottom of the spout before tightening. Note...be sure that the jaws of your basin wrench are firmly around the nut only as not to mar and gouge the threads on the spout shaft. It is also helpful to have someone else hold the spout in position at the top side in order to tighten it properly. Some of the moen models (depending on place of purchase) may have a nut with set screws in it. You get the nut as tight as you can by hand and with a screw driver tighten the screws which will be visible and the heads will be facing down at the sides of the spout shaft. If you can't seem to locate what I am describing post again and I will try to locate a diagram for you.
Apr 26, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
I have a single lever Moen faucet where the handle is very loose and there is no button on the back side that would reveal an allen key, so I cannot tell how to tighten it back up. What should I do?
On almost all moen single handle faucets there is no allen set screw to hold handle on. They are secured by a screw located under Moen emblem in the center of the faucet on the top. You usually can get to the handle screw by prying cover off with small blade screwdriver or point of knife blade.. Tighten screw and hopefully this will fix your problem. Thank you.
Nov 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
I have a Moen Faucet I believe a 7065 with a separate spout, lever handle and side spray. I take off the cap and go to remove the Allen screw but it will not turn or come out. My faucet has the water...
Sep 11, 2010 | Moen 7065ORB Vestige Single-Handle Kitchen...
Don't know model of my faucet but it is designed similarly--faucet is separate from spout. The handle doesn't stay in position unless it is on full force. Otherwise, it shuts off.
Take it off (the handle) and tighten the bolt underneath it that adjusts the pressure. My husband is a plumber and he said it's a simple fix. Hope this helps. To get the handle off- take the cover off and there's a screw underneath it- take it off and then tighten bolt
Dec 31, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
The handle is loose. It's a single lever control. The mechanism the level connects to still works fine. No leaks, but the handle is now quite wobbly, and I don't know how to tighten it. Do I pry out that...
Remove the plastic red and blue insert or what ever color yours is under the handle in the front. Tighten the set screw with an allen wrench. Be careful not to over tighten or the screw will break off.
Dec 27, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
My moen single lever faucet is loose, how do I tighten it?
On the back side of the lever you should see a button cover. It pops out exposing a allen key. this will tighten the lever
Nov 02, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen 87135c - cant take apart
Oct 03, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
48 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
