Pvr error code 0bf1
PVR spin on boot and then go into error 0bF1 and restart to boot but end again in ObF1 error
SOURCE: Humax PVR 9200T freezing picture and will not turn off.
Unplug the aerial; switch the PVR On; if you have control via the remote do a reset to default settings thus:
1. press Menu on the remote
2. select Installation and enter default password of 0000 unless you have changed it
3. select Default settings and okay on YES
4. then turn if off again via the remote
5. plug the aerial back in and it will scan for channels, save them of course.
I got help on this from other forums but saw your request for help. This worked for me.
Posted on Dec 14, 2008
leecom72
  • 4806 Answers
SOURCE: My 9242 HD PVR is constantly freezing. Is there a
Try unplugging the unit from the wall for a couple of hours to see if the unit will reset. Also you could try and see if there is a firmware update for the unit from the manufacturer.
Regards.
Posted on Aug 17, 2009
SOURCE: bell pvr 9242 hard drive failure
YOU NEED TO TAKE IT OUT AND PUT IT IN AGAIN BUT MAKE SURE ITS IN RIGHT
Posted on Dec 30, 2009
SOURCE: i have a bell 5200 pvr and while watching tv the
Bell sent me two mobel 5200 receivers by mistake. Can I operate them as a single tuner if I only have one line in?
Posted on Jan 08, 2010
  • 212 Answers
SOURCE: I have an error code 01 on my sagem PVR set top
Unplug the box from the mains and leave fro 15 mins. Unplug the antenna (aerial), plug back into the mains and switch on. It will show 09 error; ignor. Press ók'on the remote. The box will reset and reboot into stby. Plug antenna back in and switch on. With a bit of luck you will be able to do an automatic channel scan (refer to your manual).
Er 01 refers to a failed upgrade, so you may have corrupted firmware, which is not good.
Posted on Jan 18, 2010
How do I connect DGTEC PVR to Toshiba TV?
Hi Bronwen,
You might want to double check if there is cable loose or not connected to the right slot ( on the back of tv and pvr ).If still not work check the input lists and check one by one and there should be one of them is the right input. Hope it helps.
Apr 27, 2014 | Televison & Video
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
Non system disk or disk error
Hi is the bios detecting the hard drive? Are you able to open the laptop and chek if the hard drive is correctly plugged into mother board
Feb 06, 2013 | HEWLETT-PACKARD 625 Notebook PC
Why wont my HP COMPAQ nx6110 boot up!!
1) Download (0x00000007b) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Jul 03, 2012 | Computers & Internet
XP rebooting again and again
Do you now have both hard drives plugged in? You must have the Master hard drive in the IDE1 slot and the second hard drive jumpered to cable select and put on the IDE2 slot. As you are looking at the cable from the open side of the computer, the IDE cable connected to the hard drive should have the red stripe towards you. The end of the ribbon cable should be plugged into the primary hard drive, with the second hard drive plugged into the second plug on the ribbon cable. On the hard drive there should be a diagram for how to jumper each hard drive for primary or cable select.
NOTE: You cannot put a hard drive into the computer and expect it to boot, even if it has an operating system on it. The OS must be installed onto the hard drive after being installed into the system.
Good Luck,
NOLA Tech
Jan 31, 2010 | Compaq Presario 5000 PC Desktop
Qosmio G35-AV600 boot problems
You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
Thank You, Arjun
Apr 01, 2009 | Toshiba Qosmio G35-AV600 Notebook
Installing a hard drive on the eurovox ex5000 pvr stops it workin
if the hard drive is new and not formatted , there will be no operating system for the computer to go past the bios start up
what you will have to do is to get into the bios , select boot preference and select cd as first preference
load an operating system( example win 8) and let the unit boot from the disc
after that has properly installed ,shut down the unit , restart and get the bios back up and change boot preference to hard drive
from then on it should start and boot from the program on the hard drive
Nov 13, 2017 | Televison & Video
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Disk read error, please help
If it was dropped on the floor, more than likely, that spinning hard drive is damaged and has failed. The computer caqnnot load the operating system. You will definitely have to replace the hard drive, and hope the data is recoverable. Keep in the mind, the hard drive is constantly spinning, and any shock at 30G's or more can be fatal.
Picture moving a turntable while its playing, accept, instead of spinning at 33.3 rpm's its spinning at 5400 rpms, faster than most car engines......
Good luck.
Dec 16, 2007 | IBM ThinkPad T43 Notebook
Televison & Video Logo
344 people viewed this question
Top Televison & Video Experts
