Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Pci simple communications controller download driver
please go to this link and download your drivers for your motherboard....you may have to download or install drivers for your hardware addons that you installed as well..
Support For H55M E23 MSI Canada Motherboard The world leader in...
Apr 26, 2014 | MSI H55ME23 Motherboard micro ATX LGA1156...
Pci simple communication controller
PCI Simple Communication Controller is a 56k PCI Modem, to know which exactly you have, use Unknown Device Identifier ( Download Here for free ), that will tell your the Model and Manufacturer, then Google for the drivers.
Sep 27, 2013 | Western Digital Computers & Internet
Driver HP G62 corei3 pci simple communications controller
if you have pci simple communication controller as unrecognized device it's mean that the modem driver are missing. just click this link to download the driver
May 23, 2011 | Computers & Internet
Drivers for pci simple communication controller for toshiba
Check out the Toshiba Support Site.
Select your Toshiba model to download the require drivers.
PCI simple communication controller - ie the 56K internal modem drivers.
Hope it helps.
Mar 23, 2011 | Computers & Internet
I cannot use internet for my modem driver has ? i need driver for pci simple communication controller. please help me.. so that i could use internet again. i'm using windows xp.
Look for the brand name of your modem and model. You can find it in the box of the modem. If you have it then go to there website in the internet and download there the driver.
Nov 29, 2009 | SimpleTech SimpleStation (STI-PNPR/PCI) PC...
Asus EN7200GS
PCI simple Communication controller refers to a modem which is installed in your computer but with no driver installed.
Here is the web address for your graphics card:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Regards,
Graemevm
Apr 20, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
104 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
