Question about Biostar P4M900-M7 FE Motherboard
No onboard sound after video install
Installation of ATI video card with DVI connector knocks out onboard sound. No sound connector on video card. Only "disable" and "auto" options available for sound on MB BIOS. Cannot "enable" with BIOS. Video Card is Hp 5188-1678 RV370XT Video Card: http://www.ascendtech.us/hp-5188-1678-rv370xt-video-card_i_vcrv370xt256vtd.aspx Best driver I could find using XP pro is ATI Radeon X300/X550/X1050 Series. Is there a better driver that will not cut out onboard sound?
5 Suggested Answers
aceltix
  • 119 Answers
SOURCE: Disabling Onboard Video
no you dont need the jumpers or some from there...just before booting your OS,go into the bios field.
there you will find the option you must set to disable.
the exact point youll find it I cant tell you because bios are different from board to board..depending of the manufacturer..just surf the bios,youll find it and disable it
good luck bye
Posted on Feb 07, 2008
SOURCE: Video card installation
I have a Geforce Graphic's card it was working a few weeks ago but now my system aint detecting it now.
Posted on Jun 11, 2008
  • 17 Answers
SOURCE: Added nvidea 9300 GS card and Audio devices disappeared
shouldn't be tied together. find your onchip audio drivers from either your motherboard manufacturers website or your motherboard disk if you have one. what does your control panel -> sound and audio devices look like?
Posted on Dec 19, 2008
graemevm
  • 519 Answers
SOURCE: Cannot set resolution 1640x1050
To answer your question in short: If your video card and monitor drivers are installed correctly and you are able to adjust the resolution to 1640x1050 in your settings then your card and monitor are able to handle that resolution.
Remember that at higher resolutions your display card performance might become very slow.]
This is due to your BIOS shared memory being only 64Mb.
To get better performance you will have to upgrade your display card to one with more memory. ie. 256Mb. or more.
Best of luck.
Regards,
Graemevm
Posted on Apr 22, 2009
I actually have the 512mb graphics card but my question is how do i install graphics drivers when the installation disc wont even do a complete install?
unplug power cod, open computer Cabinet panel, remove cmos for 2 min and reinsert cmos,
wipe graphics card socket, reinsert graphics card, TURN on computer, press f2 to load default setting
you do not need to disable onboard graphics. in bios, some bios default configure your graphics card to primary
hope will help you
Apr 29, 2014 | ASUS Video Card ATI RADEON HD 5450, (1 GB)...
Onboard sound lost after video card installation
If your PC had an onboard video card before this, you may want to go in and make sure you have disabled it in the BIOS. This has happened to me before.
Nov 21, 2013 | Biostar P4M900-M7 Fe VIA P4M900 Socket 775...
I have issues with the second ATI FirePro V7800 card. I am running Window 7 pro - 64 bit. The motherboard is ASUS Sabertooth X58. Intel Corei7. Corsair 24 GB. Both two cards were working fine...
In order to further troubleshoot this issue, I would recommend the following:
Uninstall the ATI drivers from your computer.
Shut down the computer.
Remove the ATI card from your computer, and connect your monitor to the onboard video adapter.
Turn on the computer.
Ensure the ATI software was infact removed.
Reinstall the ATI video Card
Turn On the computer
Reinstall the ATI drivers ensuring to select the proper "CrossFire" configuration
May 21, 2011 | ATI TECHNO FIREPRO V7800 PCIE 2GB GDDR5...
I replaced th original Ati radeon x300 video card on my hp media center m7250n for a new galaxy gt 240 for better video and also changed the power supply to a new 550 watts. Since I lost audio. The system...
Hello
The x300 is video only.There is a possibility you may have knocked your sound card out of its pci slot while working inside the case.
Check that the sound card is firmly seated in the slot.
If you do not have a sound card and are using onboard sound,reinstall the sound drivers.
Enjoy your new gt 240.
Feb 06, 2011 | HP Media Center m7250n (ED842AA) PC...
Once i connect my gt5662 to a monitor nothing is on the screen, i know the monitor is in fine condition, i realize the graphics card it came with has 2 different slots, should i buy an adapter an hook the...
Did the computer boot to a monitor before? Is this a new monitor for this computer? The GT5662 came with an ATI Radeon HD2400 PCI-e video card. There is also an onboard VGA port on the back of the computer. The VGA port should be disabled. The ATI Radeon HD2400 PCI-e video card comes with two DVI connectors. With the back of the computer facing you, you would use the one on the right. You would have to have an DVI to VGA adapter to use them unless your monitor has a DVI connector also. Hope this helps. This is what the VGA and DVI connectors look like. _498.jpgmoz-screenshot.png
Dec 13, 2010 | Gateway GT5662 Desktop PC
If i connect the DVI cable to my Video card (9200 family)and to my monitor an Asus VH222H i get a dialogue box saying no DVI signal. if i use the VGA cable everything works fine.Does this mean the card...
Make sure your monitor is set up to recieve what ever signal you are wanting via the monitor's menu. There should be an input button on the monitor to select the signal type. The connection really doesn't matter as long as you are able to use the monitor. There could be something wrong with the connector on the video card. Also make sure you are using the card and are not using the onboard graphics connection by mistake. If the problem persists it is more than likely the card.
Oct 27, 2010 | ATI RADEON 9200 Graphic Card
Instaled my ati 1650 but monitor does not work
make sure you got a vga to dvi connector or else if you were using onboard graphics before you will need to disable onboard graphics in your bios setup
Jan 26, 2010 | ATI RADEON X1650 Graphic Card
Monitor goes black after windows boots up
Try removing the video card, and look up your motherboard / system manual on dell's website on how to manually reset the bios.
1. Remove video card
2. Reset BIOS (physically opening the computer and using a special jumper and/or removing the battery...what ever the manufacturer says to do to reset the BIOS).
3. After BIOS is reset, try booting up via your onboard video card first. Once you get that working, go into the bios settings and make sure it is set to boot the onboard only for right now and then you can make sure the ATI software is fully uninstalled when you get into windows.
4. Reinstall the ATI card and boot up with the video still connected to the onboard card. See if it will let you install the driver.
The trick here is to reset the bios and get the system booting off the onboard card if at all possible. If that works, then you can always reinstall drivers and then tweak the bios to boot off the AGP card instead of the onboard.
May 01, 2009 | Rosewill RADEON 9200LE (128 MB) Graphic...
I am trying to install a new pny pci dvi video card and turn off the onboard vga adapter so the video card will work as primary display output. The pny instructions says to disable the onboard adapter...
BIOS will detect the new card..plug the cable to the new card.
before you install the new card make sure your BIOS support the interface card.
update your BIOS with latest version, before installation
Mar 20, 2009 | Computers & Internet
ATI 256MB Radeon X550 Graphics card
r u using dvi or vga? does the monitor support dvi?
Nov 23, 2007 | Gigabyte ATI RADEON X550 , (256 MB) PCI...
Biostar P4M900-M7 FE Motherboard Logo
29 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
