Question about Ariston Technologies AWD 129 NA Washer/ Dryer Combination
Door handle broke door is stuck - Ariston Technologies AWD 129 NA Washer/ Dryer Combination
My door will not open on my washer and it will not start the wash
try pulling the handle with youre left hand kind of hard & at same time push in on door with right hand close to handle work it back & forth if that don't work try jerking on handle with left hand with right one on machine gasket maybe stuck or handle broke inside door hope u luck Nick
Feb 12, 2015 | Washing Machines
O5 xle sienna driver's power window stuck open and tipped, also door handle not working
the window regulatore is bad and maybe the track is broke .you can access this by removing the interior door pannel.good luck
Mar 21, 2013 | 2005 Toyota Sienna XLE
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
Interior handle is broke and door wont lock? How much to repair?
Not enough info. It could be simply the interior handle broke and a new one is about 30 bucks. U say it won't lock. This could be cause by a stuck door lock actuater. This part may have caused the handle to break. U need to find a good mechanic & he will have to take the door panel off and see exactly what is wrong and give u an estimate. Good luck.
Sep 24, 2012 | 2008 Ford Fusion
2007 chevy tahoe driver side door handle will not open door
the linkage behind the handle either the retaining clip broke or popped off need to remove the door panel to check and fix
Mar 13, 2010 | Chevrolet Tahoe Cars & Trucks
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The driver side door lock wont go all the way up.
The outside door handle spring is broke ,or the latch spring is broke. The only way to tell is remove the door panel and inspect the rod from the handle to latch. Look for broken spring on handle. I have installed an external spring from the handle rod to latch to keep the rod in the full up position.
Nov 18, 2009 | 1999 Ford Ranger SuperCab
Need instructios to repair 1997 Toyota Camry Broken Exterior Door Handle
Two 10mm bolts, or nuts, hold the handle on from inside the door. dont forget to remove actuating rod from old handle. probably clip is broke also.
May 30, 2009 | 1997 Toyota Camry
Washing Machines Logo
21 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
