Question about Small World Toys
Instructions for teepee,from active edge megamaze
I can't find the instructions for the teepee from this kit. I can't figure out how to keep the poles in place and to keep[ the tent from sliding down.
jaballou
  • 63 Answers
SOURCE: I desparately need some assembly instructions for my Barbie tent.
Mattel products, including Hot Wheels, Barbie and Polly Pocket:
In the US and Canada: 800-524-8697
Posted on Dec 09, 2008
ward_knutson
  • 64 Answers
SOURCE: need an instruction booklet for Wild Country Blaxland 64283 Tent
If you go to www.coleman.com Use the product services link for product manuals. You can then choose tents. Or you can use this link:
http://www.coleman.com/coleman/images/pdf/2000000136.PDF
Posted on Dec 16, 2008
SOURCE: ripped outwell tent
log onto http://www.imagescotland.com/scottishmountaingear-home.asp
this is outwell's recommended repairer!
Good luck
ps. putting the pins in is very tricky - needs strength and patience!
Posted on Aug 20, 2009
SOURCE: I need new poles for Swiss Gear tent # SG33071F
Go to Home depot and buy a tube that fit the pole. Cut it into 5 or 6 inches for the broken areas. It costs me less than 2 dollars. Let me know how it turn out on yours.
Posted on Aug 25, 2009
SOURCE: where can i get assembly instructions for great outdoor tent
You can get instructions for Great outdoor tents if their not too old from Great Outdoors Hastings
Posted on Dec 13, 2009
Do not have instructions how to set it up?
What type of tent?
Typically, aluminum poles are "vertical",
while fiberglass (flexible) poles are "horizontal" (to support the top of the tent).
Aug 21, 2015 | Sport & Outdoor - Others
Delay start keeps activating & can't seem to turn it off as per the instructions. I have some how locked it. Lock symbol on with no other display but to scared to unlock it incase the delay start comes...
Turn mains power off and back on to see if there is any change in behaviour. Possibly some sensor is on its edge and about to fail Buy a Finish cleaning kit from super market and run the dishwasher on a hot cycle with the kit per instructions on the bottle. This will clean any dirt in side.
Feb 05, 2014 | Fisher and Paykel Dishwashers
Can't elevate the pole
Hi, on the center pole there is a collar that turns, raise the pole then turn the collar clockwise to tighten, hope that helps
Feb 02, 2014 | Invacare 4 Leg I.v. Pole
Lost the instructions to Elmers Sour Candy Activity Kit.. I need to know where I can get the instructions.
Not sure you still need the instructions ha. I was looking for them myself & came across your post. I finally found them after searching a bit. Here's the link, scroll down to where you see instructions & click on it Sour Candy Kit Fun Science Kits for Kids by Scientific Explorer
Feb 20, 2011 | Scientific Explorer Elmers Education Sour...
Need instructions on how to restring the spiderman shakespear rod
i just followed this kid on this video and it worked for the spiderman shakespear kids fishing pole. http://www.youtube.com/watch?v=XddYxI4ZF0c
Jan 18, 2011 | Shakespeare Spiderman Fishing Accessory...
I have a Ryan's Room tent, and some of the plastic pieces that make the frame of the camping-style tent broke. How can I get a replacement part?
We had the same issue. Here's my solution.
Each tent pole is composed of 49.5 inches of half inch pvc pipe cut into three 16.5 inch pieces. This can be purchased at any hardware store. You can cut it into three pieces like the original and string an elastic line through it or just keep a piece of 49.5 inch pipe in storage to use when needed.
G Barth -- gb4cities@comcast.net
Mar 16, 2010 | Small World Home Sweet Home By Ryan's Room
Lost the instructions for circo monster play tent...need to set up for kids asap..
2 short poles A 2 longer poles B 1 medium pole C
Slide one assembled A pole through the pole sleeve at base fold and fasten the velcro tab over the end of the inserted pole repeat with other A pole on other side Slide one assebled B pole through the pole sleeve at rafter. (across the body) fold and fasten velcro tab repeat with other pole slide one assembled C pole through the pole sleeve at top (down the middle of the monster) Put plastic mold at the end of the inserted pole into the pole at front
Feb 19, 2010 | Toys
We just purchased a used '99 Starcraft Field & Stream PUP. There were no instructions for setting up the awning. I need step-by-step ''how-to'' help since everything I've found says, ''raise support...
I had exact same problem on my 93 popup. I finally figured it out. First, the poles with the plastic rings slide into the poles with the metal rings. These are the vertical support poles. Next, the poles w/ plastic nipples slide into the other poles with rubber ends. When put together the poles with the nipples should be spring loaded. These spring loaded poles rest against the top of the camper and the nipples are inserted into the 3 holes of the pole that go across the front of the awning giving you rafter support. The tension from the spring should keep the pole in place against the side of the camper. The first 3 poles with the plastic rings go from the ground to the front awning pole where the nipples can slide through the plastic ring and then into the awning pole. The vertical poles can be adjusted for height by sliding them up or down and then twisting them like a screw to tighten them up and keep them in place. 2 of my 3 vertical poles will not lock when I twist them so I have to get tricky with them. The metal rings, which should now be at the ground, are there so that you can stake it down under windy conditions. I hope this wasn't too confusing but I beleive it will help you. Good luck!!!
May 14, 2009 | Sport & Outdoor - Others
Toys Logo
134 people viewed this question
Top Small World Toys Experts
ray gallant
Are you a Small World Toy Expert? Answer questions, earn points and help others
