Question about Sportcraft 40 in. Spongebob Turbo Air Hockey Table
Where can i get the handle for the spongebob turbo air hocket table?
Missing a handle/hand piece for the table
Im 9 years old and i need to draw spongebob for my school activity. please help me .thank you
The easiest way to draw Spongebob is to get a copy of him and put it under a piece of paper and trace over the lines.
If you get a picture of him and put a blank piece of white paper on top of it, you can still see Spongebob right through the white paper. Take a pencil and trace over the lines of his picture on the white paper. When you are finished tracing the lines, you will have made your own spongebob picture.
Please make sure that tracing a picture is "ok" for this assignment with your Teacher. If your instructions were to draw your own picture of Spongebob then tracing someone elses picture of him could get you into trouble.
If you can't find a picture of spongebob to trace, here is a link to one that you can use:
http://www.google.com/imgres?imgurl=http://www.glitters123.com/glitter_graphics/Sponge_Bob/Sponge-Bob-Glitters-2.gif&imgrefurl=http://www.glitters123.com/glitters/sponge-bob/&usg=__RTcUD-OEzyLvXytYF_fnwIf_jbo=&h=363&w=367&sz=141&hl=en&start=0&zoom=1&tbnid=p52X0Lmh5jxu0M:&tbnh=138&tbnw=140&ei=cnwVTqKEEYeQsQLNxJVK&prev=/search%3Fq%3Dsponge%2Bbob%26um%3D1%26hl%3Den%26sa%3DN%26biw%3D1024%26bih%3D599%26tbm%3Disch&um=1&itbs=1&iact=hc&vpx=141&vpy=251&dur=1003&hovh=223&hovw=226&tx=91&ty=99&page=1&ndsp=15&ved=1t:429,r:5,s:0&biw=1024&bih=599
Click on the link above and it will open a website that has a picture of sponge bob. Print a copy of that picture and use the method above to trace a copy of it.
If you dont have a printer, click on the link above to view the picture of spongebob on your computer screen and put a piece of white paper over the computer screen and use a pencil to trace over the lines using that method. Be careful not to press too hard or you might damage your computer monitor screen.
Jul 07, 2011 | Televison & Video
How many watt it have?
    Features and Benefits:
  • Powerful 3 speed turbo fan for fast focused cooling power or enhanced air circulation
  • High performance blades rotate for maximum air velocity through the wind tunnel turbo grill
  • Pivoting head can be adjusted in a 90 degree arc for varied air distribution
  • Versatile design makes this fan great for use on desk and table tops
  • Wall mounts with separate purchase of hardware
  • Equipped with a carrying handle for transport
  • Dimensions and Weight:
  • Size: 6.33" x 11.375" x 11.125"
  • Weight: 3.5 lbs.
    Power 50W @ 110V
    Power 60W @ 220V
Feb 14, 2011 | Honeywell HT-800 Table Fan
I'm missing a ''tilt'' set screw on my Craftsman 10 inch table saw
I couldn't find that model Sears saw to confirm, but if yours is like mine (113.298720), then the handle on the right causes the saw trunion to swivel left and right. And there is a locking hex-head bolt on the front of the saw up close to the underside of the table. This bolt locks the trunion in place keeping it from swivelling.
Take a look at the following diagram http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0908018-00004.png part 22 is the shaft that tilts the blade Part 30 is the bolt that locks it in place part 29 is the handle part 28 is the spring that holds the handle on the locking bolt
Mar 19, 2010 | Craftsman 10" Table Saw
I have just gotten my Hitachi 10'' compound mitre saw (C10FCE2) out of the box, and have disengaged the packing pin, and put on the stabilizion bar and handle. I can not seem to get the blade to tilt back...
the hndle at the front is for your mitre. there should be one at rear of tool to bevel (COMPOUND) IT SHOULD HAVE A HANDLE AS WELL possibly left hand thread !
Jan 04, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
Turbo air sandwich table too cold
Replace the thermostat which is located on the back of the unit underneath the bins in the very back. If the thermostat goes bad it will let everything just run and run and run. If this has been helpful please rate
Feb 12, 2009 | Turboair Turbo Air Sandwich Salad Table...
Sportcraft Turbo Hockey table will not power up
The customer service is somewhat oblivious to their inventory and products they sell. But, if your table is not pushing the puck, call and order a new fan (easy swap out). Also, you may use a small pin and poke each air-hole as dust accumulates and clogs system (do not use a wax or polish, only damp soft cloth)
The control box is the interface to power scoreboard.(kids pushed the transformer cord in too hard and separated the circuitry panel inside CB). I am in process of replacing mine, model number 34090, part number 34090HG08, $5.00+ SH
There are comparable control box modules for similar turbo hockey games, Atomizer, which uses a similar control box that you can swap circuitry out to your old box. (Very simple, even a cave man can do it..hah). The key is the ability to put control box back together once you disassemble inerts. (The "flip" mechanism is so shoddy it never goes back together right)
Good luck with Sportcraft and their disposable $500-600.00 air hockey tables which have a lifespan of parts of less than 5 yrs!
Nov 17, 2008 | Fat Cat 7' Air Hockey Table
My SpongeBob lazer mouse doesn't right click
Ok, if you open up the mouse, there is a little piece of plastic that presses down on a button in the mouse, if the right click doesn't work, that little piece of plastic is probably broken. I know you like that spongebob mouse, but you'd have to get a new one. Check ebay.
Jun 19, 2008 | Kidzmouse Nickelodeon Sponge Bob...
Bissell Pro Heat Turbo 2X
Here are things to check when there is no spray from hose or nozzles.
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
May 29, 2008 | Vacuums
Sportcraft 40 in. Spongebob Turbo Air Hockey Table Logo
54 people viewed this question
Top Sportcraft Sport & Outdoor - Others Experts
Are you a Sportcraft Sport and Outdoor - Other Expert? Answer questions, earn points and help others
