Onkyo ht s3300 hdmi board problem - Audio Players & Recorders
nonontech
  • 4737 Answers
SOURCE: Dear Sir, I have purchased Onkyo
It would be better for me to advice you if at least you did mention the price range so that I can refer you between your budget for the same. Since your Onkyo Unit is 5.1, I would highly recommend you to get a 5.1 channel Speaker for the best output and performance. If you prefer a high-end for home, then you can check out this Logitech's Z5500 (Click Here). The price is around $359 and the performance is excellent.
If you would just want to play music and songs at home, I would recommend this Logitech Z506 (Click Here), it's a Surround Sound Speaker and the price is about $100.
Both the machines are compatible with your Onkyo Tx-SR308.
From other brands like "Creative" you can check out here (Click Here)
Still more here, but don't get the Wireless or USB.
If you have problem or if you need further help, please let me know.
Good Luck.
Thanks for using FixYa.
Posted on Dec 20, 2010
SOURCE: onkyo ht-r960
I had the same problem at 1 year after purchase. I was upset. In addition to looking here, I also emailed the company. They took a month to get back to me, but their solution worked perfectly.
"Try resetting the unit by pressing VCR/DVR and the standby/on button at
the same time on the front of the unit while it is turned on. The unit
will display CLEAR and shut down. All settings will be erased. "
All my components connect without any problem now. Hope this helps.
Doug
Posted on Jan 17, 2011
SOURCE: I just purchased the Onkyo
It is because you have speakers "B" selected. Only select "A" and the rest of the menu will show up.
Posted on Feb 19, 2011
  • 11 Answers
SOURCE: Onkyo HT S3300 center, left
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Posted on Apr 29, 2011
SOURCE: Only video, no audio from
Okay so I know this is a little delayed I had the same issue and what I found out by calling ASUS, is to right click on the speaker icon bottom right of screen, click on playback devices. If your HDMI is connected to both tv and laptop, then your TV should be listed. the speakers should have a green check, click on your TV then press set default, then configure test. After testing hit okay and you are good to go. You just have to turn it back to your laptop speakers same way. Good luck hope this is more useful than the typical "Check your manual."
Posted on May 01, 2011
Hdmi output and inputs are no working. Only one works and I have to use it for everything just unplugging it and plugging hdmi cable running from bluray or game into cbl
I understand from your original message the main HDMI output works, and only one of the HDMI input is working. Which HDMI input is working? Bluray, Cabl/sat, or Game? Are you able to select the working HDMI input either from the remote, and front panel of the receiver, or just from input of the receiver?
Double check your settings for Audio output and HDMI controls (found on page 36 and 37) of the owner's manual.
Jan 06, 2014 | Onkyo HT-S3300 Theater System
Only stand by mode is on
power supply in the unit is most likely or it is in shutdown because of a short----a owner manual is unlikely to help.
Dec 21, 2012 | Onkyo home theater system HT-S3300 User...
ITS NOT RUNNING
hook it up and set it up correctly.Use the quick setup guide and manual provided.
Apr 02, 2012 | Onkyo HT-S3300 Theater System
No Audio in HDMI THRU Onkyo HT-R380 Receiver
Hello, I am sorry about your issue. I suggest that you contact us at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Mar 03, 2017 | Onkyo HT-S3300 Theater System
How do u plug in a dvd player
the onkyo receiver should have hdmi jacks on it labeled cbl/sat,dvd, and so forth. plug the hdmi wire into the dvd and from the dvd to the hdmi jack on the onkyo that says dvd. then run another hdmi cable from the hdmi out jack on the onkyo receiver to the tv
Oct 21, 2009 | Onkyo HT-SR800 System
57 people viewed this question
 Grubhead
Grubhead
