Question about Kyocera RI-3530 Black and White Copier
Copier problems I have a xerox 420dc copier. When you turn the machine on it states a scanner fault. I followed instructions to turn machine of, unplug, & plug back in. Nothing has changed. Are there any suggestions?
  • awad Nov 05, 2007
    New Friend:
  • 120 Answers
Make sure the scanner lock control is not in the locked position. It might be located right above wher the copy comes out. a round knob.
Posted on Jan 26, 2008
  • 208 Answers
If you havent cleared this. What fault code is it declairng?
Posted on Dec 05, 2007
  • 58 Answers
Sounds like its stuck, try removing the glass and moving the scanner assy. manualy. move it all the way to each side then put in the middle. turn the power on and watch it,if you still have the problem you most likely will have a bad home switch or sensor.
Posted on Oct 17, 2007
How do I unlock the scanner?
There is a green lever underneath the scanner (where the copies exits). Push it towards the rear of the machine.
Oct 07, 2014 | Xerox CopyCentre C20 Black and White...
Trashing xerox 420dc due to main failure. I've heard there is a hard drive or memory card that I should remove. Is there and where?
Hi Scunning84, I don't have the solution but I too am trying to figure out where the hard drive is in this copier? Were you successful in locating it? Thanks for any help you can offer. Carrie
Nov 04, 2010 | Xerox Document Centre 420 DC Laser Printer
Fault 094-322
i have problem code 094-322 how cant i solve ?
May 22, 2009 | Xerox DocuColor 12 Color Copier
Scan failure
Anything with scanning problems on this machine, would require a service call.
Turning off and wait for at least 30 seconds and powering on the machine "Might" get the machine back to a good "Ready" condition.
The problem might be a bad scanner motor gear or even curciut board. There might even be some major binding that might knocked out some sensor, giving this condition.
Most times, a service call needs to be placed with Xerox.
Mar 13, 2009 | Xerox Document Centre 420 DC Laser Printer
At the lcd screen you can read this message: "ESCANNER DESABILITADO"what should I do?
The scanner probably got accidently locked. Turn the machine off, unlock the scanner, then turn back on.
Instructions on how to unlock the scanner are found here:,/?St=143,E=0000000001181477675,K=8219,Sxi=11,Case=obj(349)
Dec 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
We have a Xerox M20 Copier/Scanner/Fax/Email which we have always used strictly as a copier. We need to use it as a scanner, to reduce paper in the office and access/share documents electronically. I...
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
Sep 22, 2008 | Xerox Office Equipment & Supplies
Xerox ducu centre 420dc wonte come to ready. no error code turn it off and on clears sometimes but takes a lot of trys
When the machine comes on. There is a cable that runs from the scanner to the processor. When the machine is ON, unplug it and re connect it . It should reboot. That cable most likely needs replaced. But try disconnecting and reconnecting it with the machine on.
Jul 29, 2008 | Xerox Office Equipment & Supplies
Xerox 420dc it indicates that it is still warming up and stays there. The screen will not change from that message. I have powered off overnight etc.
2 things to try. First, turn the machine off and pull open all the paper trays. Just pull them out about 6-8 inches, turn the machine on with the paper trays pulled out, then one at a time push them back in.
If that doesn't work, then with the machine on, there is a cable that runs from the scanner to the processor. Looking from the front, its on the left side of the machine, on the back, it is a fairly large molex connector. Unscrew the two thumb screws, then unplug it and plug it back in with the machine ON. It will force it into a reset and may boot.
If neither of those work then most likely the software will have to be reloaded due to corrupted software.
One other note I found..
The problem is caused by a software glitch when Tray 1 paper size guides are set to an unrecognised size (for example, the rear guide at A4 and the right guide at 14"). This confuses the machine, which subsequently declares a system fault. This does not affect trays 2, 3 & 4.
SOLUTION: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
Check the tray 1 settings and ensure that both paper size guides are set to the appropriate paper size, then power off/power on the machine.
Apr 29, 2008 | Office Equipment & Supplies
Kyocera RI-3530 Black and White Copier Logo
93 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
