Question about Jilbere De Paris Ion Tourmaline Series Flat Iron
Flat iron turns on but doesnt get hot - Jilbere De Paris Ion Tourmaline Series Flat Iron
My Gold N Hot flat iron will not heat up
Suspecct failure of the heating element, use a continuity tester to check the element or the connection to the element as the mains wire is OK. Disconnect the power to test.
Jan 17, 2014 | Gold N Hot Gh2168 Professional Ceramic...
Sedu flat iron
because it is automatic so it turns on and off after heating at a certain temperature it turns off automatically.
May 16, 2013 | Sedu Pro Ionic Ceramic Tourmaline Flat...
Chi flat iron!
My chi doesn't have a dial for heat. When you flip the on/off switch it heats up. You cannot turn heat lower or higher. Just turn it off if it gets too hot.
Apr 22, 2013 | Health & Beauty
I plug it in and turn it on and it doesnt turn on no matter what
You should check out www.flatironrepairs.com. I bet it can be fixed.
Aug 27, 2011 | Chi Ceramic 1 inch Flat Iron GF1001USA
Gets hot then shuts off
Most flat irons come with a safety setting where as soon as they get to a certain temperature, they shut off (to keep the customer safe). Try turning the setting down to a medium-hot. Also, if it stays on for a long time it will shut off by default to help with accidentally leaving it on. 1. Try turning the heat down 2. Don't let it set for long 3. Try hitting the reset button. Sometimes the settings get shifty, so resetting the device can sort out the problem. 4. If none of the steps work, take it back. There is something wrong with the flat iron, like a short in it.
Apr 08, 2011 | Chi Ceramic 1 inch Flat Iron GF1001USA
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
SHARK STEAM STATION G6200 SUDDENLY STOPPED WORKING.
take it back to the store and tell them what has happend the only thing i can think of is that one of the wires has come loose within the cable
Apr 21, 2009 | Euro-Pro Shark GI490 Iron
SHARK IRON WITH TANK.GREAT BUT SUDDENLY STOPPED.
these along with coffeemakers have a thermal fuse for safety the fuse looks like a cilinder with one flat side and the other side pointed with a wire protruding on both sides. it is located inline with the heating element under the cover "Appliance Parts" on the internet sells the part
Black & Decker Iron - Steam Advantage - won't turn on
Just open your flat iron and locate the face plate contactor that has a soot burn causing the filament not to heat,use a sand paper to clean the contact from soot burnt,this the common problem of a flat iron...
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 10, 2008 | Black & Decker Steam Xpress AS250 Iron...
Jilbere De Paris Ion Tourmaline Series Flat Iron Logo
Top Jilbere De Paris Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Jilbere De Paris Health and Beauty Expert? Answer questions, earn points and help others
