Question about Makita Garden
Chainsaw leak bar oil
No oil on chain
  • 35 Answers
SOURCE: Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Posted on Dec 31, 2008
SOURCE: chainsaw wont oil the chain and bar it is a poulan 2000 woodsman
It's probably the oiler check valve located on the crankcase just in front of the clutch. You will probably need to remove the clutch and sprocket to get at it.
Posted on Mar 06, 2009
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Posted on Apr 24, 2009
  • 10865 Answers
SOURCE: chainsaw leaks chain oil when not in use
The oiler on most chainsaws is designed to be gravity fed. For that reason, if there is oil in the oiler it will drip out. There is no fix to this except for awareness. When possible stop work when you need to refill the oiler. when not possible, expect it to leak and plan for it. for example, store the saw in a tray with some oil-dri absorbant clay in the bottom.
Posted on May 06, 2009
SOURCE: Chainsaw bar is dry. Chainsaw is full of oil.
I have Poulan 2375 Wild Thing and auto oiler stoped working. After disassembling I found the oil pump plastic driven gear was damaged by the metal drive gear. The gear was damaged because iol pump was locked up do to dirt in pump. The replacment pickup line has a filter the pump and line kit sell for around $12.00 at Home Depot on line a simple repair for any one with some mechanical abillity.
Posted on Jul 01, 2009
What can be done to stop leaking oil?
Gary, not sure what oil you are talking about for sure, if it is chain/bar oil it is suppose to leak/lube chain while it is running.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://familywoodworking.org/forums/showthread.php?9424-Are-chainsaws-supposed-to-leak-oil
Husqvarna chain oil leak repair 346
Husqvarna 254 Chainsaw Bar Oil Leak Repair How To Remove Clutch
May 25, 2016 | Garden
Poulan chainsaw oil leak
sounds like the small oil feed pipe inside oil tank as come away from the end. just push it back on you may need a pair of long snout pillers.. good luck
Nov 30, 2013 | Poulan Garden
My poulan pro chainsaw dies when I give it gas and I think the bar and chain oil is leaking out during storage.
try and run it with the muffler off the build up with carbon and restricted the exhaust flow as for the oil leak mine the screws became loose behind the clutch for the oil pump
Sep 17, 2012 | Poulan Pro 20-inch 2-cycle 50cc Gas...
Chain oil leaking on 025 stihl chainsaw
Their is a oil passage that has a plastic plug in it by the muffler. It might be gone like mine is.
Nov 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Leaks bar oil
The chainsaw squirts oil into the oil hole in the bar. The chain picks up the oil and carries it all the way around the bar lubing it and the chain. When you quit running the saw there is still a lot of oil on the chain and all away around the chain guide in the bar. Once you quit running it and it sets a while all the oil will follow gravity and run to the bottom of the bar and drip out into the case. It's just another one of life's little nuisances. Have a nice day! Obwhon
Oct 01, 2009 | Poulan 1630 16" Chain Saw
I have a Poulan 20" chain saw that keeps leaking out the bar oil every time I put it in the container and store it. What causes this and can it be fixed by myself?
Most chainsaws have an adjustment for bar oiling and its quite normal for a chainsaw that is stored for long periods of time (weeks or even days) to leak out the bar oil. This is normal for chainsaws stored for several weeks or more.
Some of it may be reduced by adjusting the rate of flow for the bar oiler, read your manual carefully before attempting to adjust it. Adjust to too slow a flow rate will have adverse effects on performance and can lead to premature chain or bar failure.
Recommend that if you are going to store your chainsaw for more than a couple of weeks, drain the bar oil back out if it into a container (strain it through a paper towel before returning to your bar oil can). Also, you really should drain almost all the fuel and then run it until it shuts off if you are storing it for a month or more.
Aug 05, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain moves while idle
Hello there. Regarding the bar oil, many loggers plan their work so that they are out of bar oil at the same time that they quit for the day because bar oil has a tendency to leak. Another method that has some success is to mix your bar oil with a heavier oil but the trade off might be less lube getting to the chain when you need it.
Regarding the chain moving in idle, this is another common problem. You can usually slow the idle down until the chain stops, as you indicated, but I too have had chain saws where I finally just decided to live with it and be extra attentive to what was going on.
Jun 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Stihl 180 chainsaw,lack of oil to chain and bar
Apr 14, 2009 | Garden
Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Apr 10, 2009 | Garden
Garden Logo
29 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Are you a Makita Garden Expert? Answer questions, earn points and help others
