Question about Stamina Products Stamina Ux2 Air Resistance Upright Exercise Bike
Won't calculate The meter shows all 0's and won't calculate when Riding?
My BA II plus professional showing wrong answer while computing "N" during TVM calculation
Make sure you have P/Y set to 1 and BGN/END set to END. With those settings, pressing 9 I/Y 9 2 0 FV 1 0 0 +/- PMT CPT N should produce 7.00 .
Aug 25, 2012 | Texas Instruments BA-II Plus Pro...
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
Meter to kilometer
There are 1000 meters in a kilometer and 3600 seconds in an hour (60 seconds per minute, 60 minutes per hour).
Press 8 0 0 / 5 0 * 3 6 0 0 / 1 0 0 0 =
or 8 0 0 / 1 0 0 0 * 3 6 0 0 / 5 0 =
The result should be 57.6 kph.
Nov 11, 2011 | Casio FX-115ES Scientific Calculator
Convert 8000 square Feet in Metric
One foot is exactly 0.3048 meters, so 8000 square feet is 8000*.3048^2 square meters.
Pressing 8 0 0 0 * . 3 0 4 8 ^ 2 ENTER will give you about 743.
May 11, 2011 | Texas Instruments TI-83 Plus Calculator
Using the t1-83 show me how to do the following 800(1+0.02)to the 20th
Almost exactly the way you typed it.
8 0 0 ( 1 + 0 . 0 2 ) ^ 2 0 ENTER
^ is the key just above the divide key.
Feb 16, 2011 | Texas Instruments TI-83 Plus Calculator
How to convert cbm into sq meter
Now cubic meter calculator can be defined as a simple device which is used to convert a given value in meters to it's corresponding cubic meter form. Other than this we can always add the formulaes of the structures to get the volume of the structure by simply entering it's side length or height etc..
Let us consider simple examples :
Suppose that we have to convert 5 meters to its cube. The only thing we would do is that we would enter this value of 5 in the calculator and calculator with do the calculation as mimetex.cgi?%5cdisplaystyle%7b%7b5%7d%7d%5e%7b%7b3%7d%7d and will show the result to you as 125 mimetex.cgi?%5cdisplaystyle%7b%7bm%7d%7d%5e%7b%7b3%7d%7d .
Now if we have added formulaes to this calculator , like for calculating the volume of cube,cylinder and cone (say). Then we can use this calculator in three different cases.
Visit anthony's tuition class. Specialist in H2 Physics Tuition and H2 Maths Tuition.
Feb 10, 2011 | Office Equipment & Supplies
My calculator shows 0.00000000 instead of 0 every time. How should I fix it? All the functions works properly, but there are too many zeros for me.
At the top left of the calculator, you will see a sliding switch that is labeled: DECIMAL A,0,2,4,6,F. Move the indicator to the "0". This will remove all excess zeros. The numbers represent how many decimal places the screen will show. I have the manual for this calculator if you need it. LBrown18062@hotmail.com
Jan 03, 2011 | Citizen CX80 Scientific Calculator
Percenteg Function problem in my Casio MJ - 120 Model Calculator
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
From Thailand
Mar 12, 2009 | Casio Office Equipment & Supplies
Stamina Products Stamina Ux2 Air Resistance Upright Exercise Bike Logo
Top Stamina Products Exercise & Fitness Experts
Tom Chichester
Bill Boyd
Are you a Stamina Products Exercise and Fitnes Expert? Answer questions, earn points and help others
