Question about Cuisinart Stainless Steel Soap Dispenser
Won't turn on and dispense soap - Cuisinart Stainless Steel Soap Dispenser
My flow indicator won"t spin but water dispenses
Check the belt on the soap pump. Water may be dispensing but soap is not mixing with it when the indicator is not spinning.
Feb 11, 2015 | bissell"" pro heat 2x select upright deep...
Dishwasher soap dispenser
If the dishwasher's turn dial isn't on off the door will not shut. Try turning the dial to off on the front of the washer.
May 15, 2013 | Dishwashers
Soap won't dispense from tool sprayer
Here's a quick link to some helpful tips. http://www.bissell.com/FAQDetail.aspx?id=1064&cid=ccsocial
Here's a link to locating a BISSELL Authorized Service Center if you continue to have difficulty.
http://www.bissell.com/service-centers/?cid=ccsocial
Dec 01, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
Soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Aug 15, 2012 | Asko D1716 Built-in Dishwasher
My Asko D1716 dishwasher works fine apart from the soap dispenser. It won't open to release the soap.
Most likely it's a corroded door catch or a bad solenoid. Hopefully it's not the main control board. You'll need a repair manual or technician. A work around would be to use detergent tablets in the compartment
Mar 02, 2012 | Asko D1716 Built-in Dishwasher
Dishwasher soap dispenser won't open
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 10, 2011 | Hotpoint Dishwashers
Whirlpool quiet partner I soap dispenser won't close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
May 18, 2011 | Whirlpool Dishwashers
How to use soap dispenser on Karcher K2.87 power washer
Also, be sure the cap is turned to the direction that lets the soap in. It has a gradation on it and if it is turned all the way to the smallest (cap fully closed) very little soap will be injected into the stream.
Apr 18, 2010 | Karcher Garden
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
Cuisinart Stainless Steel Soap Dispenser Logo
517 people viewed this question
Top Cuisinart Home Experts
Donni Steen
Tom Chichester
Are you a Cuisinart Home Expert? Answer questions, earn points and help others
