Jeep patriot drain hole - Heating & Cooling
How much is electronic throttle control for 2008 jeep patriot
why ask use , it varies by town and every dealer on planet earth.
so.>???
why not just look.
ill pretend USA car
http://www.factorychryslerparts.com/
all there , 24/7 just look,
posted 10,000 times .
Aug 04, 2014 | 2008 Jeep Patriot
The paassenger door power window wont come up on a 2008 Jeep Patriot
sure pull of door card( the cover)
and turn the motor by hand.
or disconnect it, and raise the window by hand then jam a stick in there top hole it up, flintstone style. (been there, done that)
Jan 26, 2014 | 2008 Jeep Patriot
Can't Locate a Haynes manual for my 2007 Jeep Patriot , Do you know of any other manuals which I could substitute for the Haynes.? thanks.
Doing this search on ebay gives 5 hits. 2007 Jeep Patriot (shop, repair) manual
If you take out Patriot, there are 84. The hits for a google search are endless.
This is something you can do yourself.
May 09, 2011 | 2007 Jeep Patriot Sport
Remove & replace window cranks---- Jeep patriot 2009
you need to use a window crank removing tool and remove handle. Make sure window is all the way up before reinstalling handle on splines.
Mar 05, 2010 | 2009 Jeep Patriot
Patriot 2008 2.4 on starting from a stop if I hit
It is your shock, it has come loose.
Feb 04, 2010 | 2008 Jeep Patriot
I have a 2008 Jeep Patriot and my dash board overheats
Hi I have been working for jeep for 8 years and i have found that to be normal on the Dodge Calaber,Jeep Paitriot,Jeep Compass cause they are all based on the same vehicle .
Nov 17, 2009 | 2008 Jeep Patriot
How do I check the level of fluid on a transmission for a jeep patriot 2007, it doest have a stick!!! to check it
Go underneath and look at tranny, There will be an upper filler plug and a lower drain plug. You can get top and hose for your gear oil / tranny fluid and fill. The level of the fluid should be exactly at bottom of hole
Sep 28, 2009 | 2007 Jeep Patriot Sport
Remote key for 2007 jeep patriot
Should say in your manual. If not most can be reset by standing within 2-4 feet from engine compartment and depressing two buttons on remote. Should hear an audible beep or doors should lock. Hope this helps!
Mar 30, 2009 | 2008 Jeep Patriot
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
