Question about Plantronics Discovery 640E Wireless Headphones
Wireless bluetooth won't connect to phone
It flashes green and blue while connecting after a few seconds says; paired but not connected
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Plantronics Master
  • 1,001 Answers
  • High quality,guarantee you enjoy a clear sound in noisy occasion.Powerful rechargeable battery provide 5 hours of Talking/Playing time. Rubber adapters, unique flexible design and custom earbuds ensure you get it perfect fit and remain stable in your ear
  • Special and flexible design custom earbuds will ensure you enjoy it and remain stable in your ear
Robot Check
Posted on Dec 26, 2016
    New Friend:
  • 6 Answers
May not be compatable with ur phone check the internet site for the bluetooth to see if its compatable.
Posted on Nov 22, 2013
  • Lelion Siskey Nov 22, 2013
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
Before using, you must first charge your headset.
20 minutes = minimum charge
2 hours = full charge
Light is solid red when battery is charging.
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off.
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a Nokia E75 and am unable to pair my Plantronics Explorer 210 with the phone. I tried to hold the big button down for quick pair mode. When I try to pair, it says unable to create bluetooth...
hello,
Step One:
Prepare Phone-
Turn on Bluetooth
(Or see the user guide for your
phone.)
Step Two:
Prepare Headset-
Pairing Mode
Step Three:
Pairing-
For passkey enter 0000. Headset
and ready to use.
for 2 seconds until the light flashes
and blue. hope it works
regards
shaun
Oct 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Have blackberry flip phone, blue tooth worked fine,now shows bluetooth:disabled, can't get it to work HELP gene
Hi to enable Bluetooth follow the steps given below: 1. Click on OPTIONSfrom the main Menu 2. Click on Bluetooth then 3. Click on the Menu key (which is next to track ball) 4. click on Enable Bluetooth If you find any problem please contact the Service Provider of your SIM Thank you for using Fixya
Nov 13, 2009 | Cell Phones
It always flip light
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Jan 10, 2009 | Motorola Mobility Bluetooth Hands Free...
GE Bluetooth connectivity
5) Select the Explorer 3XX device and click add
Hope this helps
Season's Greetings from Fixya
Chris (ziraffa)
Dec 26, 2008 | GE Bluetooth In-ear Headset Wireless...
Bluetooth won't connect
follow the steps below:
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 24, 2008 | Motorola Mobility H550 - Bluetooth Headset...
Cant connect logitech bluetooth to phone,
the logitech head piece buttons must not be working, seems to charge ok but can't get to flash blue?
Aug 07, 2008 | Logitech Mobile Freedom Wireless Headset
Plantronics explorer 330
I just figured out how to reset the 3XXPlatronics 330. The guest might of of made it a little confusing for some:
1) TURN OFF bluetooth head set by holding the volume control button for about a few seconds until it flashes blue.
2) Make sure your phone's bluetooth is on and on discover mode.
3) Turn on the blue tooth head set (NOTE: HOLD DOWN THE VOLUME BUTTON UNTIL IT FLASHES BLUE AND RED)
4) Lastly, go into your search menu to find new bluetooth devices. The device should show up as "3XXPlantronics" (PASSKEY IS 0000).
P.S. Keep in mind this worked for me, but if it doesn't work feel free to email me at; cispy006@yahoo.com
Mar 15, 2008 | Plantronics Explorer 330 Headset
Plantronics Discovery 640E Wireless Headphones Logo
248 people viewed this question
Top Plantronics Audio Players & Recorders Experts
Steve
Lawrence Oravetz
Are you a Plantronics Audio Player and Recorder Expert? Answer questions, earn points and help others
