Question about Tech 21 PW60 Power Engine 60 Powered Guitar Speaker Cabinet
How do you remove the front grill-cloth on power engine 60
I just want to remove the front grill cloth so I can put some duct tape behind it to act as a beam blocker
  • Eugene Martindale
    Eugene Martindale Feb 12, 2014
    There is a small hole on the inside right corner, use a small screw driver and push it through. The front grill will release and push out and you can take it off from there. The grill is attached by velcro
  • Eugene Martindale
    There small hole on the inside right. Use a small object and push it through the hole. The grill will push out and you can then remove it.
    The grill is attached by Velcro.
Freezing up
This is a 2 1/2 ton unit, if it is a package unit, usually the installer has to install a filter rack in the return air duct. Try opening the side panels and see if they installed a filter rack in the unit itself, if not it could be in the ductwork itself, usually there will be a filter slot cut into the side of the sheetmetal duct, on the side, you remove the cover and replace the filter.
Now if you still have not found the filter, there is one more place they could be, in the structure there are large grills, these are your return air ducts, if you put a tissue on it, it will **** the tissue to the grill, sometimes these grills are hinged and the air filter is installed inside, just behind the grill.
If you still can not find it, then the installers, forgot to install one. Good Luck
Contact me if I can help you furthure.
Paul Gibson
Jun 15, 2010 | Intertherm P3RA-030K Air Conditioner
Natural gas grill blows out in wind
Hm. Didn't like the idea of putting duct tape on my brandy new weber but thats what I did to keep the burner lit today in the wind. The 4" open area on the back, covered it with three strips of duct tape. Also stuffed aluminum foil in the right side to somewhat plug that crack. Trying to cook the ribs slowly (low flame on the second burner only which usually gives me about 225 degrees) and its windy as heck today. I surely don't plan to leave the duct tape there. Will probably invent a metal thing that slides up and down to cover that gap.
Apr 02, 2010 | Weber SPIRIT E-210 (NG)
How do I change out a 2005 murano grille? THANKS
This is out of my 06 Murano manual, hope that it helps.
REMOVAL
1. Apply protection tape around outer circumference of front grille (bumper fascia side).
2. Remove front grille-radiator cover clips and remove front grille-radiator cover.
3. Remove clips on upper side of front grille.
4. Remove clips of air duct and remove air duct. Refer to EM-16, "AIR CLEANER AND AIR DUCT" .
5. Pull out grille pawls, and remove front grille assembly.
Installation is the reverse of removal.
good luck
Feb 26, 2010 | 2005 Nissan Murano
I have a 42inch Toshiba Rear Projection television, my son got water on the screen and it has leaked into the screen behind the flimsy plastic front screen. How can i take off the front panel to clean the...
WELL YOU MIGHT HAVE TO SEPARATE THE 2 PIECE SCREEN. CAREFULLY TRIMMING THE TAPE ALONG THE EDGES. WIPE WITH A CLEAN CLOTH IN THE DIRECTION OF THE GROVES. UP AND DOWN ON THE FRONT-LENTICULAR LENS. AND IN CONCENTRIC CIRCLES ON THE FRESNEL LENS. TAKING THE SCREEN OFF IS EASY. REMOVE THE SPEAKER GRILL AND YOU WILL SEE THE SCREWS HOLDING IT ON.
Dec 27, 2009 | Toshiba 42H81 42" Rear Projection...
Do i just clean the air filter or buy a new one?
clean it - pull out the bucket, look under the front panel lower lip, remove any tape, and pull down the slide-in filter (it fits behind front grill) - just vaccuum and/or rinse and put back in - the tape was just for shipping.
Nov 17, 2009 | Maytag M7DH65B2A Dehumidifier
How to replace head light on 2004 maxima?
"The bad news is that to be able to access the 3 other bolts that hold the light assembly together, you have to remove the front bumper. including the grill. It is really not that hard, but you should take your time to do it right and to make sure you put it back together the same way. To remove the bumber you must unscrew to screws that are located inside each wheelwell behind the cover. I found it easier to remove both front wheels and hold the car up in stands unfront. these are the only screws that you will find, two on each side. after that just remove the black self taping screws from the grill and then reach behind the grill and compress the tabs that hold the grill to the bumper. remove the grill and then keep removing the self taping screws until the bumper comes off. BE CAREFULL to not let the bumper drop as it still has your conner lights connected. you can disconnect the corner lights or just place something to support the bumper. Hope this helps you, If you take it to the dealer they charge a labor of about $250.00 plus parts." -http://www.nissanclub.com/forums/2004-2008-nissan-maxima-gen-6-discussion/237350-2004-nissan-maxima-se-headlight-bulb-replacement.html
check out other fourms on this website and others to find diagrams and more detailed instructions on how to change the headlight
Aug 06, 2009 | 2004 Nissan Maxima
2001 Jeep Grand Cherokee Laredo- radiator fan
I need to know what all has to be taken off, the easiest way, to replace a radiator fan motor for a 2001 grand cherokee?
Oct 16, 2008 | 2001 Jeep Grand Cherokee
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
Lint pile up
Hello Lintjammed ( I like the name).. You may be able to add a skinny tube to your vaccuum cleaner to get down in that area.. Most hardware stores sell clear tubing by the linear foot and it is not very expensive or you may be able to salvage a piece of old garden hose to make that extension tube.. It has to be skinny enough to fit into the open area where your filter resides.. I have used tubing and some duct tape or electrical tape to transition the bigger vac line to the smaller tubing.. Hope this helps you..
Oct 01, 2008 | Whirlpool LTE5243D Top Load Stacked...
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Tech 21 PW60 Power Engine 60 Powered Guitar Speaker Cabinet Logo
55 people viewed this question
Top Tech 21 Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tech 21 Audio Player and Recorder Expert? Answer questions, earn points and help others
