Question about Rheem EcoSense by 4.2 GPM Tankless Water Heater LP Gas
Ptg 74pvn 2 rtg 74pvp
Hi Dear! My Eco sense thankless water heater model # RTG74PVN2 provide 3 minute hot water only. On the thermostat screen appear code C4 76 when I reset by turning the thermostat off and on it appears normal temp. of 120 I also can't increase or decrease the temperature. Can you help me to solve this problem?
  • Rheem Master
  • 5,245 Answers
Copy following links for rheem/eco-sense error codes, manuals, required yearly maintenance, support number and resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Probably bad PC board, or bad remote control
Gene
h
Posted on Nov 22, 2013
gary1121
  • 332 Answers
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
Posted on May 29, 2009
snap101
  • 117 Answers
SOURCE: Model PTG-74PVP-2 Error Code A0 21
check to make sure the air vent is clean and that the front cover is on properly
Posted on Aug 11, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
  • 244 Answers
SOURCE: I have a paloma tankless water heater about 3
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Posted on Nov 06, 2009
  • 244 Answers
SOURCE: PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Posted on Dec 06, 2009
My ecosense tankless water heater #rtg-74pvn-2 says c8 13
It could be the ods sensor ,or may require adjustment of burner manifold pressure . you might want to contact Rheem 800432-8373
Mar 06, 2013 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
Rheem RTG-74PVN-2 code c776
Communication fault with remote, but also bad PC board.
Copy following link for troubleshoot resources:
Oct 13, 2012 | Rheem Tankless Hot Water Heater...
Paloma tankless water heater model no PTG-74XP-2 error code c8
In several cases i have had to change the pcb board.... code 76 is no communication between remote thermostat and pcb..... this is a problem the first generation rheems seem to be having.... contact rheem if under warranty you will need to get pcb and program chip sent to you. Really need a experienced tech to install board and program it for you...... hope this helps...
Jan 25, 2012 | Rheem Paloma Tankless Water Heaters...
I have a poloma model PTG-74PVP hot water heater. This morning we went to use it and it will run a minute or two the flash alarm 35. We have had the unit for four years with no problems what so ever.
rtgl-74xp.jpg RTG-95XP Item Name: Outdoor Rheem Tankless Water Heater RTGL-74XP Item Price: $910-$1100 Gas Type: Propane Venting: No Item SKU: Rheem RTG-95XP replaces RTG-74XP Product Description: Rheem Tankless Water Heater RTG-95XP
Be aware of this --- http://www.cpsc.gov/cpscpub/prerel/prhtml07/07108.html
And this ---
This makes getting information hard to come by. Please use the link below for information.
http://www.rheemtanklessonline.com/contact.php
Feb 06, 2011 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
I have a Paloma PTG-74PVN tankless natural gas water heater. It was installed 3 years ago and has worked great until 2 days ago. Currently, the water heater will run for approximately 10 minutes, i.e....
Try turning the thermostat uo a small amount and see if this makes a difference. I suspect the control board is bad but I would try adjusting t-stat before I spent money on board or service call. Thank you
Dec 16, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem tankless rtg 74pvn - heater hot water shuts
This is something you will have to contact rheem about due to the fact you don't have a fault code
Jul 13, 2010 | Rheem Tankless Hot Water Heater...
Rheem RTG-74PVN-1 Water heats for abot 2 minutes
overheat stat or fan, on fan check for small pinhole in rubber tube best of luck
Oct 16, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Model PTG-74PVP-2 Error Code A0 21. No hot water.
Aug 10, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
May 18, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem EcoSense by  4.2 GPM Tankless Water Heater LP Gas Logo
204 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
