Question about Rowenta Compact Steamer - White
The rowenta compact pro steamer stopped steaming and needs to be cleaned. how do i go about cleaning it?
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
DiYerTech
  • 70 Answers
SOURCE: Rowenta DM273 Self Cleaning Function
Attached below is the Rowenta website to obtain PDF copies of the manuals. If the hyperlink does not work, cut and paste it into your browser's address line. There are also links to download Adobe Acrobat Reader to allow you to view and print the documents if you do not have this program. Please advise if you find this helpful...
http://www.rowenta.com/rowenta/frame.aspx?page=http://www.rowenta.com/rowenta/consumer_care/use_n_care/downloadInstructions.aspx?RblCategory=Download
Posted on Jul 14, 2008
DiYerTech
  • 70 Answers
SOURCE: CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Posted on Jul 26, 2008
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
SOURCE: My Rowenta Garment Steamer will not steam up.
Ok. This thing is caused by scaling. If the steam generator runs out of water the sensor thinks the tank is empty and causes the machine to go to standby (basically switch off -- orange light comes on). The solution: Open the machine and clean it.
MAKE SURE THE POWER CABLE IS UNPLUGGED BEFORE ATTEMPTING TO DO THE FOLLOWING:
1. There are six screws ( phillips - you will need a long screwdriver). Two of them are hidden under the wheels (just pop off the rollers and you will see the screws)
2. Open the steam generator (there are four screws) and be very careful with the 'O' ring -- you damage it and you can say good bye to the machine. Clean it if you see scaling. The amount of scaling present would indicate how hard your water was. This itself may not be cause of the problem but now that you openend the machine, you might as well as clean it for better efficiency.
3. Disconnect the hose to the steam generator (it has two circlips) and clean it. Mine had hard deposit of scales preventing the water reaching the steam generator.
Re assemble it.
Good Luck
Alex0714
Posted on Apr 10, 2009
Rowenta microsteam 400
You need to follow the instructions for the iron. Rowenta make a excellent iron but it's water tank and steam chamber need to be cleaned and rinsed out, say every third use depending on how much you use it. Also, allow the iron to reach FULL TEMPRATURE before you use it.
Jul 29, 2014 | Rowenta DW-8090 Pro Master SEWERS Iron...
Why won't my red light quit blinking?
each time you clean the steamer or refill with water always press and hold the reset button for about 30 seconds, whiles the steamer is on.
hope my answer helps you.
May 10, 2014 | Rowenta DG-980 Iron
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
My steamer steams and then shuts off and it takes another two minutes to steam again....what is wrong?
the power light stays on but steam only comes out for 30 second.and it takes few minutes to steam again.
Oct 21, 2012 | Rowenta Commercial Garment Steamer - White
Rowenta Professional Iron - steam button suddenly stopped working
Have you tried descaling it? It may well be blocked up with limescale. Personally I only ever buy cheap irons and bin them when they go wrong! As you say-they are generally too expensive to repair.
Jun 11, 2009 | Rowenta Professional DX8900 Iron
Is there a product to run through a rowenta pro garment steamer to eliminate build-up?
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
May 14, 2009 | Rowenta Commercial Garment Steamer - White
Rowenta Steamer
Same thing with my daughter's..any solution out there?
Jun 22, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta Compact Steamer - White Logo
157 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
