Question about Nextbook Premium 8 Se Android
Charging light blinks red - Nextbook Premium 8 Se Android
When I plug in my device and try to turn it on the battery light glows red and a red light instead of a blue one will light up and I know I have charged the battery
at least you think you charged the battery . I would take it to a computer repair shop and have them check the battery
Oct 11, 2015 | Tablets & eReaders
When I attempt to charge using USB charger the charging light is red for a couple of seconds and then goes off. I have only just received this case/keyboard. It is obviously not already charged since the...
Turn the keyboard on and let it run all the way down. Then try charging again. If the Red light stays on, the keyboard has was charged. If the same conditions exist, then arrange for a replacement.
Mar 28, 2015 | Tablets & eReaders
Why does my Mophie have 4 blinking lights
Use a paperclip to short the two terminals in the usb output Jack. The two at the opposite sides of the jack. I have to do it before almost every charge.
Oct 29, 2014 | Mophie juice pack powerstation duo, juice
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Why is my power light blinking red on my coby tablet?
You won't find a manual. Coby went out of business several months ago. It might be time to replace it. Sorry.
Aug 02, 2014 | Coby MID70244G 7 KyROS TABLET TOUCHSCREEN...
Unable to charge tablet. Used several different cable. Red charging light only blinks maybe.
You may have to get it fixed. The same thing happened to me before. And I got it fixed.
Jul 26, 2014 | Amazon Kindle Fire HD
Kindle Fire Will not charge
you might want to consider posting your question in a fan based support forum such as this one:
Amazon Kindle Fire Forum on XDA Developers
Have a Magical Day
K
Light keeps blinking pass the 30 second mark
If it's flashing all lights fast at same time....don't worry. My mophie juicepack powestation does this all the time and refuses to take any charge. I bend a paperclip into a u shape and short the pins in the usb output Jack for not even a second. Quick touch is all that is needed. NO LONGER OR RISK DAMAGE OR FIRE. Resets the chip inside. Charges fine then.
Mar 19, 2014 | Mophie juice pack powerstation duo, juice
Screen has began to flash on and off and wont charge
I had a similar situation with my pipo s1. After further investigation I found that the jack the charger cord plugs into went bad. My charge light wouldn't stay on unless you held the charger plug in a particular position. The jack is hardwired into one of the circuit boards and to replace the circuit board was half the cost of the whole tablet. I junked it and bought a kindle fire. Better quality and longer lasting battery.
Dec 12, 2013 | shop-fun PiPO S1 7 inch Tablet PC Android...
Blackberry tablet wont power on
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
May 04, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Nextbook Premium 8 Se Android Logo
62 people viewed this question
Top Nextbook Tablets & eReaders Experts
bigdawg7299
Beej West
Level 1 Expert
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
