Question about Sub-Zero 30.1 cu. ft. Cabinet Depth Side-by-Side Refrigerator 632 / F
Sub zero side by side
Vacuum condensor light come on intermittently evry few days. i have vacuumed the top coils
    Director Badge:
    Uploaded 100 video answers.
  • Sub-Zero Master
  • 488 Answers
evaporator leaks freon, made a video on how to replace it
Posted on Jun 27, 2015
  • 175 Answers
Yuor sub zero is low on freon in the fridge side. if you call sub zero they will cover the repair, even if its not under warranty, as long as you use anathorized servicer. they had some failures of the evaporater in the fridge that caused the freon leak. Don't let the repair person who comes out tell yu it needs a compressor, that will only fix it temporarily. Good luck!
Posted on Oct 11, 2007
Sub zero 690 vacuum condensor light flashing, clean vac. condensor, light still flash after 2 days.
I assume from your post you have vacuumed the condensor at the top of the unit? Did you do this regularly over the life of the unit? You have shut the unit off for at least 5 minutes (allowing it to reset) and then turned it back on and the vac condensor light still flashes? I had this same thing happen - unfortunately for me I have had to replace the condensor twice in the 12 years I have owned the unit. Luckily first time was covered by warrantly (parts and labor). Second time was in the 11th year and the parts were covered, and the labor was covered 50% after I complained......It ended up being a leak in the sealed system (condensor). If it keeps happening you may want to call for service - could be that it just needs freon, but it could be the condensor)
Sep 08, 2010 | Sub-Zero 690 Side by Side Refrigerator
Outside of freezer on left upper side..it is very hot on the outside..the refrigerator is saying service as well..
sounds like the condensor needs cleaning and the service light is telling you its dirty . the unit runs too long when dirty and does not cool properly . also can cause or shorten the compressor life. mm p s clean . turn of power remove top cover and use a coil brush and vacuum .
Aug 11, 2010 | Sub-Zero 632 / S
Code vacuum condensor
clean your condenser coils. located in the top part of the fridge. unplug the unit before service. vaccum the condenser. if after 2 or 3 weeks the vaccum condenser comeback is really posible that you have an evaporator freon leak. in the fridge side
Mar 29, 2010 | Sub-Zero Bottom Freezer Refrigerator
Have a sub-zero 601F about 10 years old and the 'vacuum condensor' light is flashing whenyou open the door in the same box as the temperature.
You should first vacuum condenser coil on top (looks like radiator coil in the car), then try to reset it by turning it off and back on. Otherwise it indicates that it's running too much and most likely it's not getting cold enough.
Sub-zero repair in Orange County, CA
Jan 23, 2010 | Sub-Zero 601R
My light says "vacuum condenser". I cleaned coils and fan and turned unit back on. Light came back on in few days, also don't know where reset switch is. Thanks
Good day,
The power off/on switch is the reset proceedure on most Sub Zero's however, it initially comes on when the unit senses the temperatures are too high, leaving the compressor.
It also is a known fact that a Sub Zero condenser cannot be cleaned by vacuuming only.
Service techs use either compressed air or nitrogen with a hose to blow the condenser clean.
Lacking that, a good push -pull shop vac with a crevice tool makes a good substitute.
Remove top grille, and the cover plate for the compressors.
Aggressively blow the condenser out from both sides.
Make sure it is clean, by shining a light on the inlet side, and making sure you can see thru the fins.
It's ugly, dirty and makes a real mess,
But the option long term, is winding up replacing the compressor(s).
Dec 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
Vacuum condensor light flashing and the refrigerator won't get colder than 51 degrees.
The light is indication a problem with the condenser coils being covered with dust/dirt and cannot dissipate the heat energy absorbed by the system in the evaporator coils (freezer). Or the condenser fan is not running. Clean the condensor and/or check the fan.
Nov 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
Where are the coils on a sub zero 680? Vacuum condenser signal
Hello.
On the top of your unit there is a grill. Open both door and look at the lip under the grill. Remove these four screws. Now, pull on the top of the grill. You will notice that it is held on by two springs. Unhook those springs and set the cover aside. The coils are on the right hand side. Use a vacuum with the soft brush attachment to clean them and avoid damaging the airflow. Also, check the fan on the other side of the coils to make sure it is running.
Jul 16, 2009 | Sub-Zero 680 / F
My vaccume condensor light is flashing and my refrigerator is 55 degrees. I vaccumed the coils on the side of the fan What could be the problem ?
You may need to unplug the fridge for a few hours and let it reset itself. Also make sure coils are clean and there is plenty of air flow to the condensor..
Jul 09, 2009 | Sub-Zero 690 Side by Side Refrigerator
Vacuum condensor
open both the freezer and refrigerator doors, there are 4 screws at the top of the door frame that extend into the grill covering above the doors where the condenser is housed.  Remove all 4 screws, pull the grill open and then use your home vacuum to clean the dust from the condenser coil (it'll be obvious that it needs it).  Close the grill back, replace the screws and the message should go away.
Sep 08, 2008 | Sub-Zero 642
Refrigerators Logo
338 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
