Question about Airstrike Bell 1800 Floor Bike Pump
Convert bell airstrike to presta valva - Airstrike Bell 1800 Floor Bike Pump
3 Suggested Answers
formeat
  • 6 Answers
SOURCE: how do I use the Bell AirStrike Digital Floor Pump
The gauge measures three different amounts. Be certain that you have it set to PSI. Then set the target PSI. The green LED indicator will then flash when you are within 5 PSI of your target and will flash constant when the target PSI is reached.
Posted on Aug 30, 2010
anupam19
  • 263 Answers
SOURCE: Where Can I get a new hose for my Bell AIRSTRIKE
Go to ebay.com
Posted on Mar 13, 2011
Airstrike Bell 1900 , the hose is ripped. What do I need to do? How to replace it?
Always a good idea to contact the manufacturer: The Bell Garage or a bike shop may be able to help. The pump may accept a different brand hose.
Sep 13, 2013 | Airstrike Bell 1800 Floor Bike Pump
How to attach bontrager pump to presta valve
This pump does not need any presta valve adapter, the head unit is a dual unit for both presta and schreader.
1. On the bicycle tube. Open the valve by unthreading the small metal cylinder located at the very end of the valve stem. DO NOT force the the bead to come off of its threading. A couple spins counter clockwise will do the trick.
2. Insert the valve stem into the filler head. The lever on the back of the filler head should be "down" at this time.
3. Connect the filler head to the valve stem by lifting the lever on the head "up".
4. The valve stem and the handle on the filler head are now in parallel to each other, basically inline with each other.
5. START PUMPING.
6. If loosing considerable air while pumping, Try reinserting the valve in to the filler head, deeper, for a more secure fit.
If the issue persists, use a presta valve adapter on the valve stem. Traditionally used to convert presta valve heads to schreader heads, for use with filler heads not compatable with presta. A one dollar part available at any bike shop. Usually used in a pinch while airing up at gas stations or with schreader only pumps.
Dec 27, 2012 | Bontrager Supercharger Floor Pump - cycle...
I am trying to figure out how to put air in a presta valve. The tire is just a little flat but we couldn't seem to fill it at the gas station. I think the bike may have been used when we bought it.
You can not fill a presta valve at a gas station because the valve is too small for the hose. The hose at a gas station is made to fit a schrader valve.
here just check out this video:
http://www.youtube.com/watch?v=9byRp9e2USU&feature=related
hope this helps.
Sep 23, 2011 | Bell Sports Bell Universal Bicycle Inner...
How do i set up the pump to inflate a presta valve tyre?
If it is not a Presta pump, then you will need an adapter. These adapters usually run for less than a dollar and are easy to use. You can just screw it onto the Presta valve and then it converts it to a Schrader. You can see what they look like HERE. They should be available at any bicycle, camping or hiking store. Good luck and be safe riding! (Helmets are your friend)
Mar 04, 2011 | Topeak Peak Master Blaster Dx Pump
How do you fill the tires on this bike. The valve stems are not typical bike tire stems. I am (obviously) a novice biker and have not owned a bike in several years. The pump I bought is a Schwinn pump...
There are two types of valve stems, schrader ( like the valve stems on your car ) and presta. See images on this page http://www.sheldonbrown.com/brandt/presta-schrader.html Since you are asking I assume you have presta valves. You can get an adapter to convert the presta valves for use with a schrader pump. Unscrew the small knurled nut on top of the presta valve to open it, press down and release the small top to ensure the valve is free to move. Snug up the top when it is full.
Dec 23, 2010 | Schwinn Midmoor 700c Men's Hybrid Bicycle
Need new hose , where can I find this for airstrike 1800 model
Has anyone found a replacement hose for the Airstrike 1900? And/or instructions on how to replace it?
Jun 15, 2010 | Airstrike Bell 1800 Floor Bike Pump
How do I use the Bell AirStrike Digital Floor Pump
Jan 02, 2010 | Airstrike Bell 1800 Floor Bike Pump
Bicycle tire pump won't pump.
If you can? unscrew the two pieces of the pump clean and oil it. W/D40 works pretty good.
Apr 24, 2009 | Airstrike Bell 800 Frame Mount Bicycle...
Airstrike Bell  1800 Floor Bike Pump Logo
65 people viewed this question
Top Airstrike Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you an Airstrike Cycling Expert? Answer questions, earn points and help others
