Hlr5087w fan 3
Is fan #3 the lamp cooling fan?
  • 21 Answers
You might be able to find the manual here.
Ceiling Fan Manuals
if that doesnt help then try leaving a message on the site with the manual you need and they will upload it for you.
Posted on Feb 06, 2014
High pitch sound on power up and takes a long time to come on
probable color wheel for the sound which is described sometimes as fan like or high pitched---common issue and you tube has video instructions by brand/model for replacing it.
Takes a long time to come on may be the lamp if it has not been replaced in a long time(life is 2 years) and both are the most common parts to fail in this set.
5_21_2012_4_49_45_pm.jpglamp is from another brand but typical for your set.
May 21, 2012 | Samsung HLR5087W 50" Rear Projection HDTV
My projector will go off after 5-10 minutes, started with longer periods like 30mins or more... Sometimes it worked without any problems. It has a new lamp on it and Im not sure what can be the problem?...
hi,
First of all check the lamp hour of your projector. Just reset it and try again. for resetting the lamp hour do the following.
1.Switch on the projector
2.select menu and the select lamp setting
3. In the lamp setting menu select lamp Reset and execute the same
After doing this if the problem remains then you have to check two things. first you have to check the lamp cooling fan of your projector. If the lamp cooling fan of your projector is faulty or it runs in a low speed this problem can occur. Another possibility is the faulty temperature sensor. you have to check the temperature sensor near the lamp. normally a senor with two wire fitted on the lamp Cage.
if fan is suspected then remove the fan and try to oil the fan and the re fix it and try again. for oiling the fan watch the following video.
The video is for oiling a pc fan you can follow the same to oil the lamp cooling fan
ok
Apr 20, 2011 | ViewSonic PJ406D Multimedia Projector
I HAVE SONY KDS60A2020 TV ITS PICTURE GOES OFF EVERY 3 MINUTE NAD COME BACK AFTER 30 SECOND WHILE THE SOUNDS REMAINS OK I HAVE CHECK BULB IT LOOKS OK ANY SOLUTION
hi,
may be ur tvs lamp cooling fan have some problem. check it first. if lamp not get cooling it will go to over temperature, the circuit inside will sense this and make ur lamp off. and when the lamp get cooled come back again. if the fan is working then u can hear a small "ish" sound in the lamp side of ur tv. check it is it is there.
also check ur lamp, is there is any loos contact in its connection. just open the lamp cover, remove the lamp and then refix it again. then again test the tv.
ok
Dec 22, 2010 | Sony KDS-60A2000 60" HDTV
Cooling Fan for Lamp 50V500A
If you wish to get some details; visit the site linked here. Pull up older posts.
Lamp replacement procedure to projection TVs are given.
Apr 26, 2017 | Hitachi 50V500 50 in. HD-Ready LCD...
I have purchased 3 new lamps. one lasted 900 hrs.
Your lamp is rated for 3000 hours. Is the fan working to cool the lamp? When you turn off the projector do you allow the fan to continue to run? If not the lamp is not cooling evenly and the lamp will fail. Th filters should be cleaned regularly and the vents be unobstructed.
May 14, 2010 | Toshiba TLPLMT70 Projector Lamp
Samsung HLR5078W pop sound followed by a loud buzz then shut down
Your lamp burst. This model uses a lamp housing which does not have a filter screen on it. When the lamp bursts, hot pieces of glass and mercury (very toxic) drop straight down into the cooling fan below it. Although FixYa.com (implies I'm suppose to tell you how to fix it) I am going to tell you to call a servicer and have them clean that mess out of there. It's a health issue, I don't want someone unknowingly exposed to mercury on my watch. Let the servicer know what he is getting into. I hope this helps.
Mar 18, 2010 | Samsung HLR5087W 50" Rear Projection HDTV
How to replace faulty lamp cooling fan on HL-P6163W TV
A more likely candidate is the color wheel,unless your sure it's the fan
Dec 01, 2009 | Samsung HL-P6163W 61" TV
Error message to check fan #3. Where is it?
If you take the rear of the set off and hold the Interlock Switch on the right side up,Turn "ON" the set and look for three fans,one of them will not be turning. There are two small fans and one large one. The Large Fan is the Lamp cooling fan and the two fans are for cooling the Ballast and the other one is for cooling the DMD chip Heat Sink. The two smaller fans are the same type. The Lamp Fan (Large one) part# is BP31-00024A and the two small fan #s are BP31-00001A. They are all easy to replace.
Jul 13, 2009 | Samsung HLN467W 46" Rear Projection HDTV
55 in loewe articos rear projection
You might have defective Fan if Fan stops running Lamp will not Light also keep in mind Ballast board it what turns lamp on and Fan is what keeps Lamp cool, and most of the time if set is not comming on Lamp is Bad. Call Encompass Parts 1-800-638-3228 or UED 1-800-648-6657 main 3 parts to DLP is Lamp,Ballast board ,Lamp Fan.Id say you have Bad Lamp! God Bless and hve a wonderfull Day.
Nov 02, 2008 | Loewe Articos 55 55" Rear Projection...
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
