Question about Delphi Iat Sensor Driver Side Lh Left Hand Chevrolet G20 95 94 P30 Ts10072
HOW TO INSTALL A PERFORMACE CHIP TO A 2010 SILVERADO LT 2WD
  • LEE LIPPERT
    LEE LIPPERT Nov 23, 2013
    THE MAS/IAT SENSOR HAS 5 COLOR CODED WIRES,THE PERFORMANCE CHIP I WANT TO CONNECT HAS 2, WHAT COLORS DO I CONNECT TO
How do you disable cruise control on a 2007 silverado 1500 crew cab v8 4.8 LT
cruise controls have an on/off button in the hand control that enables you to disable the cruise control. ON some stalks it is a press in button on the end of the stalk
Jul 28, 2014 | 2007 Chevrolet Silverado 1500 2WD
Engine aluminum or cast iron?
it appears that the 2WD drive LT's have the iron block while the 4WD trucks have the aluminum block
Jul 12, 2014 | 2011 Chevrolet Silverado 1500
I WANT TO INSTALL A PERFORMACE CHIP TO MY 2010 SILVERADO LT 2WD. WHICH 2WIRES DO I ATTACH IT TOO
I would research it. I thought those chips plugged directly into a port on the PCM or ECM in your truck.
Nov 22, 2013 | 2007 Chevrolet Silverado 1500 2WD
Tire air pressure difference P to LT
I would think so. P stands for passenger and LT stands for light truck. The store that sold the tires should be able to get the correct recommended pressure.
You went down from 17 inch to 14 inch rims ??
Jul 11, 2013 | 2006 Chevrolet Silverado 1500 2WD
Had a vacuum hose off the throttle body break! replaced the hose and now its harder to start. 1999 Chevy silverado 1500 2wd 5.3 lt v-8!
check for another vacum leak are all hose or lines at throttle body tight? do you have check engine light on?
Aug 17, 2010 | 1999 Chevrolet Silverado 1500
Delphi Iat Sensor Driver Side Lh Left Hand Chevrolet G20 95 94 P30 Ts10072 Logo
16 people viewed this question
Top Delphi Car Audio & Video Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
gmduvall
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
