Question about American Standard Heating & Cooling
Replace air conditioner transformer
I can't find the transformer
    Genius:
  • American Sta... Master
  • 1,363 Answers
It would be in air-handler in attic. check fuse at control board usually 3 amp that protects transformer.
Posted on Aug 14, 2015
Thermostat has no power
I think that most likely shorted out your low voltage transformer. Transformer is most likely located in air handler. You may find a blown fuse for transformer or bad transformer.
Jul 05, 2014 | Ruud UBHC Air Conditioner
My house was struck by lightning most of all my computers and tv's and phones are no working and my ac is not coming on at all. What happen to my AC unit
Hi and welcome to FixYa, I am Kelly.
The main Preinted circuit board (PCB) most likely has had a failure of the small PCB transformer. This is the most susceptable component (PCB transformer) in the Air Conditioner. Within the last 60 days I have personally experienced the exact same symtom. I replaced the PCB transformer and 1 diode on the main PCB of the air-conditioner and my AC unit is working fine. Unless you can find a source for the transformer your only option is to replace the PCB (Board).
Finding the exact transrformer for the PCB can take a very long time. It iwll look similar to this one: http://www.machsources.com/productimages/9913/pcb-mounting-transformer.jpg
If you have home owners insurance ALL STATE and State Farm often cover this type of damage. It is worth the time to find out if you are a home owner.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | Frigidaire FAC085M7A Air Conditioner
There is nothing on the display,conditioner is death.The power is coming,fuse on the PCB is OK?
Check power to transformer (220volts---24/12volts Dc) which leads to function PCB. If 24 or 12 dc is o.k, then you have replace PCB only.If no output of DC, replace transformer. Thanks.
Jan 29, 2011 | LG LS-K1830HL Heat Cool Mini Split Air...
No power to the thermastat
There is either no power to the air handler or the transformer has burned out...
The power to the t-stat comes from there....if your lucky the transformer is fused and the fuse has blown...if you replace it and it blows again then check for a short in the low voltage...
Hereis a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Oct 12, 2010 | Weather King 10AJA6001AH Air Conditioner
No voltage from 24 volt transformer power in no power out .
The transformer is burnt out... you will need to replace it... this is common and they burn out easily if a low voltage wire it shorted even for a split second, or if there is a brown out...
They best way to prevent this is by installing a 5 amp fuse ahead of the transformer in the high voltage line so that it blows before the transformer goes...
heatman101
Sep 08, 2010 | Goodman CLQ36AR49 Air Conditioner
Is there a breaker on unit 9000 itself. i changed the thermastat there was a spark and now it dont work. is there some kind of reset button??model num;ca9036vk92
It sounds like you shorted the transformer. You can check at the transformer for a control fuse - alot of time there is not one and the transformer must be replaced.
htttp://www.my-air-conditioner.com
Oct 19, 2009 | GE AJCH10ACB Built-In Room Air Cool Unit
I tried changing the thermostat (unsuccessfully) and may have blown a transformer. My AC unit will not turn on. Is this an inexpensive repair?
If you did not turn off power and or have a hot wire touching a common wire you blew the transformer. There is a possibility your air handler has a 3 amp fuse on a control board. Check it first. If it is OK,replace the transformer.
Sep 24, 2009 | Ruud UAKA030 Air Conditioner
Old carrier a/c unit
sounds like your contactor coil is shorting out.replace the contactor
Sep 20, 2008 | Carrier 38BRC048 Air Conditioner
Heating & Cooling Logo
41 people viewed this question
Top American Standard Heating & Cooling Experts
Craig Butler
Craig Butler
Tim Whalen
Mack Baxter
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
