Question about Signet Audio Players & Recorders
Signet qc8613 reduce zoom
Signet digital wireless camera system Motion sensor, does not beep when motion is detected
Contact the manufacturer for the answer but I suspect that you would not want an intruder advised that he is been recorded and a beep would do just that
Apr 12, 2015 | Signet Home Security
Hi, I have installed a signet QV 3063 camera system. The software CD doesn't have any software installed on it and hence my laptop doesn;t see the HDD when I plug it in via a usb cable. I have downloaded...
Have you tried downloading it or using web-based app? Seems this may be a good place to start:
http://software.ddcode.com/signet-qv-3063.html
Jul 14, 2014 | Cameras
Facebook screen is 10 times the size it should be, cant reduce to normal size
You may have zoomed in on your web browser.
Try pressing ctrl+0 / cmd+0 to reset the zoom to normal.
Hope that helps!
Jul 05, 2014 | Facebook Social Network
How do i reformat my signet h.264 dvr
http://softwaretopic.informer.com/signet-4ch-h264-dvr-user-manual/
Dec 14, 2013 | Computers & Internet
Signet box can't get online
Go into setting and check what IP it has and port number. Then go into port forwarding in router and input the data. There are usually 2 ports that you have to open.
Feb 24, 2013 | Home Security
Face book screen to large need to reduce
press "ctrl" and "-" at the same time it will zoom out
press "ctrl" and "+" at the same time it will zoom in
this is the same for all websites
Jan 31, 2013 | Health & Beauty
Pcviewer only searches for hdd when first installed
You need to run the program as the administrator.
This will allow the program to scan for connected dvr.
May 23, 2012 | Signet Home Security
What is the difference in the optical and digital zoom?
Find the difference below
Digital Zoom
1. Digital zoom is a part of digital cameras, and camcorders, which helps to crop the entire image, and then digitally enlarge the size of the viewfinder of the portion that is needed to zoom in on
2. Digital zoom crops the image down to a centred area with the same ratio as the original, and also interpolating the result back up to the pixel dimensions of the original. this method involves cropping, hence the resolution and quality is reduced
3. Digital zoom, crops a portion of the image and then enlarges it back to size. And due to this, image quality is reduced in comparison with the original one.
4. Using the digital zoom allows the user to get closer to the subject when the photographer wants to be discreet about taking pictures, like taking a picture of a person in a graduation ceremony.
Optical Zoom
1. While taking a picture using a Camera to want to get a close shot of the subject without moving physically closer, photographers use the optical zoom.
2. The optical zoom ratio of a digital camera measures how much the lens can actually zoom in to make subjects appear closer. Optical zoom, enlarges a picture while keeping the resolution and sharpness of the picture high.
3. There is no relation between optical zoom and the resolution of the photo, as optical zoom only enlarges the whole image or the subject to a certain range. So image quality only depends upon the mega pixel (MP) of the camera
4. Optical zoom is very useful, while taking a picture of a landscape, or to get a closer view of a subject, without reducing the quality of the entire image, like taking a picture of a Rainbow in the sky.
Regards,
Ron
// Rate the solution with 4 thumbs up if the answer is satisfactory
Jul 01, 2011 | Nikon Cameras
Zooming with Olympus Stylus 820
Hey missy0528,
There are a few reasons your images might be grainy, one of which is your image quality is set to low. I would always have the camera set to the highest resolution possible, because you can always reduce the size of an image but you can never make it bigger. Another cause of grainy images in digital cameras is the sensitivity of the camera (ISO) is set to high. Since you are only seeing grainy images when you use the zoom the reason for the grainy images is most likely do to using the digital zoom. All a digital zoom does is crop the image much as you can do in some computer applications, and by doing this you greatly reduce your image quality. I would never use a digital zoom. Your camera has a 5x optical zoom and a 5.6x digital zoom. I would only use the optical zoom. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 09, 2008 | Olympus Stylus 820 Digital Camera
Optical vs. digital zoom
It's important to understand this difference, as you could be disappointed with the results if you use one rather than the other. Optical zoom works like the zoom on a traditional film camera. When you push the button to zoom in or out, physical lens elements move inside the camera, reducing the field of view and making the object you're shooting appear closer. Digital zoom, on the other hand, has no moving parts. The camera interpolates a small portion of an image to artificially restore the file to its original size. Using its electronic brain, the digital camera analyzes what it sees and digitally zooms in, usually two or three times closer. Unfortunately, digital zoom also reduces the resolution of an image, so your picture will tend to be more pixilated than the same image taken with an optical zoom camera. If you're just snapping an image to e-mail to a friend, this loss of resolution won't be so noticeable. But in situations where the highest quality counts, skip the digital zoom and use your PC's image-editing tools to zero in on your subject.
Sep 08, 2005 | HP Photosmart 120 Digital Camera
Top Signet Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Signet Audio Player and Recorder Expert? Answer questions, earn points and help others
