Phillips 60pl9220d 37
The tv shows no picture or sound and makes a clicking noise as if its trying to turn on but cant. so i replaced the lamp hoping it would fix the problem but it didnt.i can see the lamp flash on but cuts off after bout 10 secs while making a humming type of noise.
    Top Expert:
  • Office Equip... Master
  • 34,170 Answers
The power supply may be failing.
Posted on Nov 22, 2013
4 Suggested Answers
  • 9 Answers
SOURCE: C20x lamp error
This is due to thermistor problem. Near to the lamp one thermistor will be there please check connectivity. if it is failed please change the same.
Regards,
prakasam
Posted on Apr 16, 2008
  • 5 Answers
SOURCE: Replace Lamp Flashing
Clean the cooling fans, specifically the lamp cooling fan located inside the rear cover, above the optical blocker. This is easily blocked with dust and causes overheating of lamps/shortened life.
Posted on Apr 20, 2009
welcomejee
  • 10594 Answers
SOURCE: Lamp blew, picture went then
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Posted on Sep 05, 2011
Toshiba theaterwide hd
replace the lamp on your TV, but only replace it with PHILLIPS brand. Anything other than that, will not last. We just replaced ours with Phillips and the picture is much brighter. It really shows the HD quality of the tv.
Mar 24, 2014 | Televison & Video
How do you replace the bulb in a philips dlp model number 60pl9220d/37?
Go to website like Youtube.com.Type in ur DLP tv make and model.U will have a tutoring video by some body doing the projection lamp bulb replacement.
Nov 15, 2010 | Televison & Video
My magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Phillips TV clicking sound, then cuts off
The problem of that is a loose solder on the board..
Aug 07, 2009 | Philips 52PFL7422D/37 TV
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
Jan 18, 2008 | Philips 60PP9200D Television
No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Oct 19, 2007 | Samsung HL-R6167W 61" HDTV
k24674
