Question about Numark Mixdeck Universal Dj System
My numark doesnt work i need help to fix it
It turns on but nothing else works
Why doesnt the volume on my ttusb numark record player work?
This is only a turntable. You will need an amp with a phono input to get any sound. For more information, please visit my website at audioserviceclinic.com. Thank you.
Oct 29, 2013 | Numark ttUSB Turntable
My NDX400's display screen doesn't show anything. When I turn it on, all the "characters" flash white, so I know it works. But then, it just goes blank. No matter what I do, nothing shows...
If you was to turn the deck upside down you will see 4 main screws in the corners holding the silver top to the black chassis of the deck. undo these screws and carefully turn the deck over and lift the top off slowly. I say slowly because before putting it down (you might need someone to hold it for you) you need to un-clip the white plug and there will be a data ribbon stopping you from pulling the lid away. this is the strip you need to check both ends that the connections are clean and pushed in properly (the blue strip on the connector should be facing the middle of the circuit board) be careful not to snap the connector and make sure you push it into its socket straight and not at all at an angle or it could snap. put the white connector back in and pop the lid back on and turn it on to see if worked.
Jul 05, 2011 | Numark Industries Numark NDX400 Tabletop...
Ok i just purchased my idj3 and installed all the software it camre with. Once you open software and hook up usb nothing works the lights come on but only the keylock on both and a cue and b cue and none...
Make sure you install the software in the CD provided with the iDJ3. IF you already have, try to uninstall, restart and then reinstall. Sounds like the drivers for your device was not properly loaded to your PC which cause it not to recognize. If it still doesn't work after that, I suggest that you contact Numark tech support for further troubleshooting at this link: http://www.numark.com/content54
Good luck and vote this solution if it helped you. Cheers
Mar 08, 2011 | Numark Audio Players & Recorders
Numark Omni control-iMac Problems
Did you try this turn table on another PC? It is the best way to check for I never seen a NuMark act like yours. A secondary PC is always great to have if you constantly need this turntable
Mar 28, 2010 | Numark ttUSB Turntable
My numark x6 mixer does not work, it powers on, no output
Unless you can find someone local to fix it , you'll need to get something else
it's something internal broken and probably not an easy home fix
Nov 02, 2009 | Audio Players & Recorders
Problems with installing my Numark Total Control
best used with virtual dj..... go into configuration-sound settings... the controller will not activate until the music software is running.. on the sound set up its straight forward.....
Feb 23, 2009 | Computers & Internet
Turntable
No way to fix these. Numark discontinued the parts for this model, in addition, it probably would have cost you more to repair than fix.
Junk em. Next time buy a package with Technics turntables in them. You won't regret it, and they hold their value over time.
I know Technics 1200s are not cheap, but with the money you just wasted on this package, you could have bought 1 Technic 1200.
- OPTiC
DJ Pro Audio
www.djproaudio.com
Mar 05, 2008 | Numark TT1520 Turntable
Numark Mixdeck Universal Dj System Logo
18 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
