Question about Yamaha RAV252 Remote Control WE458500
Volume button doesn't work
All other buttons work
Phone ring tone is silent
Try the volume buttons of the side of the phone. If that doesn't work it may be in the settings. Of course if you have an iphone there is a switch just above the volume buttons that silences the phone.
Oct 05, 2012 | Cell Phones
Volume down button doesn't work
hi, make sure the face pins are clean; try resetting the unit; check to see if the feel of the down switch is the same as the up switch....if not then your down switch is faulty and needs to be replaced. confirm the volume down operation by using the remote control (if available), if it works then your problem lies with the switch or a broken connection between the switch pins and the face control circuit. cheers.
Jun 21, 2012 | Blaupunkt RPD-545 CD Player
How to un mute my macbook air?
Press the mute button again. If that doesn't work, then press the volume-up button until you can hear the popping noise of the volume adjustment.
Feb 19, 2012 | Apple MacBook Air
Trying to unlock google password and it want let me get out of it
leave the phone on take the battery out this should reboot the phone
Oct 07, 2011 | HTC EVO 4G Smartphone
How do i unlock my samsung galaxy i forgot the unlock pattern and it is asking for my g mailaccount login which i do nt have
There is a thread at Android Forums about this -> link.
But if that doesn't work, well there is no other option except factory reset.First try to enter Recovery Mode. There are a few ways to enter in Recovery Mode -> video link.Once in a recovery you can easily choose Factory Reset. On upper link you can find three ways to do it, and one way of doing it goes like this, it usually works:
1. Power Off your phone2. Press and hold Volume Up button + Power button + Home Menu button (just hold all three buttons at same time until logo appears)3. Select Wipe all data / Factory Reset (you select it with Volume Up and Volume Down buttons and execute it with Power button or in some cases with Home Menu button).
If you watch videos you will find same thing.
Jul 31, 2011 | Samsung Galaxy S GTI9000 Smartphone
How to reset my samsung galaxy
METHOD TO RESET GALAXY
STEP 1: Switch off your phone, remove its battery, and then place it back.
STEP 2: Now, hold the Volume Down button and Power button. And then release the Power button while still holding the Volume Down button.
STEP 3: Now you will get a list of options to choose from. Which would be like:
  • Fastbook
  • Recovery
  • Clear Storage
  • Simlock
STEP 4: There, choose the Clear Storage option.
NOTE: Use Volume UP and Volume Down keys for navigation and Power or Home button for selection.
STEP 5: Now confirm by pressing Volume Up button (YES) or Volume Down (NO).
That is it! Now, you Galaxy S will reboot and you will find that you have reset your Galaxy S to factory settings.
Jun 30, 2011 | Samsung Galaxy S GTI9000 Smartphone
How do I turn down the volum ring on the phone
Check for buttons on the side of the phone. There should be an up and down button to change the volume either way. If that doesn't work look for setting and then sounds. From there, it should be possible to find a way to change the volume of the ringtone.
May 05, 2011 | Cell Phones
The volume button(decrease) does not work
If the button is "detached" as you say then its broken. If the headset is still under warrentee you can get a new one if not you'll need to buy one. Not fixable.
Aug 05, 2007 | Motorola Mobility HS850 Consumer Headset
Yamaha RAV252 Remote Control WE458500 Logo
22 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
