Question about managemylife.com
Replaced the motor in my LG Dishwasher and now it's leaking.
My LG Dishwasher, Model number LDF6920ST, was stopping and giving me an error message of LE. While I was trying to trouble shoot it the motor started to give off a burning smell. I decided to order and replace the motor. I installed the new motor and now it's leaking out of the very bottom. ?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Hello, please check if the drain pipes are really tied and fix in place, fallow the leak you will find where is the problem.
Thanks
Posted on Nov 22, 2013
Why my dishwasher whistles?
Whistle could be inlet water pump,leak will have to be traced could be from a number of places,poss from pump
Aug 13, 2014 | LG LDF6920ST Stainless Steel 24 in....
Lg dishwasher ldf6920st not heating/drying dishes What is the part number for heating unit or retro fit kit?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Jul 27, 2011 | Dishwashers
The wash spray arms are not turning the water line is free and not pinched water is on wiring is right whats up model its a ldf7920st
This sounds like your motor is not circulating properly, this will cause the spray arms not to operate properly, or at all. Are you receiving any kind of error code on the display? Also, how far is the dishwasher filling up?
Mar 07, 2011 | LG LDF6920ST Fully Integrated Dishwasher...
I have a brand new LG dishwasher-LDF6920ST. I
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Feb 05, 2010 | LG LDF6920ST Stainless Steel 24 in....
Dishwasher showwing LE error message
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
Aug 15, 2009 | LG Dishwashers
LG LDF6920ST Bottom spray arm dose not work
The LG LDF6920 dishwasher has an innovative "Vario" motor/check valve. It switches between full power spray on the upper arms and the lower arm. So, if you are looking inside the dishwasher to see which arm is spinning, you just have not opened it when the lower arm is turning.
if the root problem is that your dishes are not getting clean with this water conserving DW, go out and buy a name brand detergent powder - like Electrosol or Cascade. And use less powder then you have been using.
Good Luck!
Feb 02, 2009 | LG LDF6920ST Stainless Steel 24 in....
E1 Error Message
agreed all LG d/w with E1 is the wash motor faulty.
take care.
Jan 12, 2007 | LG 24 in. LD-12BW5 Free-standing...
managemylife.com Logo
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
