Question about Cambridge Soundworks 88CD CD Player
Screen shows 88.88 and system will not start - Cambridge Soundworks 88CD CD Player
About 90% sure it is the aluminum electrolytic capacitors. My unit starting acting flaky (wouldn't turn on, clock went haywire, etc). The failure was intermediate. I did a wholesale replacement on the aluminum electrolytic capacitors and it works like a champ. Coincidentally, my LCD TV of about the same age failed at about the same time and for the same reason. These capacitors have a finite life and will often fail after about 10 years.
If you are not versed in electronics repair, you'll need to find someone who has the tools and skills to do the work. The circuit board uses a ground plane which is very difficult to solder and requires either an under-board heater or hot air rework gun to preheat the plane. If you (or someone you know) is well versed, then this is how you do the repairs:
Remove the four screws on the back of the unit. Gently remove the back cover. The circuit board attaches to the cover you're removing and there are a number of connectors you'll need to disconnect between the board and main unit.
There are probably 6 screws that hold the circuit board, two that hold the aux board (base control, aux input) and one that holds the power cord retainer. Leave the aux board attached to the main board. Remove all of these. You'll also need to desolder the AM antenna wire. This is a short, black wire that connects between the circuit board and copper shielding on the cover. It solders into a ground plane, so it can be difficult to reflow the solder. Look for the round capacitors with a polarity marking. These are the ones you want to replace. Write down the voltage and capacitance for each aluminum electrolytic cap. Measure the lead spacing (critical) and case size (less critical). I used Digikey and matched the lead spacing, voltage, capacitance exactly. I matched the case size to the closest size available and got the lowest ESR value available. The lower the ESR the more effective the capacitor can move charge into and out of the capacitor (improving its effectiveness).
There is a black heat sink that wraps around the board. If you remove the heat sink, make sure you note which regulator has a plastic bushing on the screw. This regulator has a positive voltage on its case and you will short the regulator without the bushing (it also has an insulating pad that sits between the heat sink and the regulator case).
When replacing the capacitors, you'll need to pre-heat the ground plane in immediate area of the capacitor you're desoldering (or soldering). You can use an under-board heater, but if you set the temperature too high the bottom mounted components can fall off. I used a hot air solder station and heated the plane. While the plane was hot, I used my solder station and desoldered the parts. I did the same (hot air then solder gun) to install the new parts.
Unfortunately I didn't document my repairs that well (sorry, no photos). I did install the regulator bushing on the wrong regulator (hence my warning above). It took me several attempts to figure out what I had done wrong.
Good luck,
Kevin H.
Augusta, GA
Posted on Nov 22, 2014
How to solve intex UPS error 88?
check recirculation pump and heater
Jan 27, 2017 | Intex Pool & Spa
88 shows up when i turn projectmix on
It sounds like an adapter issue. The PMI/O say's to use a 9v adapter, but the manual on page 9 says 12v. Try 12v if you use 9v or vice versa.
Powering on while holding the Zoom button will enter a test mode.
To do a reset. Setup>Factory Defaults>SEL>Yes
Nov 26, 2015 | M-Audio ProjectMix I/O
Alarm 88 showing on screen.Machine starts but stops after 10 seconds.
http://www.appliancepartspros.com/repair-help/appliance-fault-codes.html
Mar 16, 2015 | Whirlpool Dishwashers
I have a 1989 or 1990 Johnson 88 special and all of a sudden, as I was running it about 1/2 speed, it died. There is still spark (as It started a few times and died immediately). I took off the cover
sounds like the fuel tank lost it's venting- try it with a loose cap. Have set my remote tank on the fuel line and had this happen, If none of this sound like it, put some clear plastic line between the fuel pump and the carb. This will show bubbles from any air leaking into the system (not good)
Aug 19, 2012 | Boating
1984 oldsmobile delta 88 charging system diagram
can i put an auto start in a 1984 olds delta 88
May 21, 2012 | 1984 Oldsmobile Delta 88
What's your problem?Need help to fix my kurzweil pc 88 ... no function just powers on but no display...need help urgent
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 01, 2012 | Computers & Internet
My system is only 2 years old & has recently started turning itself off & when I try to restart it, it will show up the 88 numbers but not allow me to put in time cycle when I push down on the...
Had the same thing happen to mine. In my case water got into the controls somehow. This showed up as steam and or water droplets showing up on the inside of the display screen. If you see the same thing than that is probably the problem for you as well. Unfortunitly had to replace mine. Hopefully yours is not the same problem.
Sep 08, 2010 | Intex Automatic Salt Water System for ...
Won't start. Light are lit, but the 'start' button does nothing.
If the display shows an '88' then place a heating pad over the display. In a few minutes the '88' code will clear, and the dryer will work. Sounds crazy, but it works for me every time.
Oct 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My unit turns on, flashes 88 and then goes dead.
Question
What does code "88" mean? What should I do if code "88" appears?
Answer
What does code "88" mean? What should I do if code “88” appears?Code “88” indicates that the saltwater system is standing by, please simply set the operation hours according to the manual and the system will start working.
Jun 21, 2009 | Intex Automatic Salt Water System for ...
Cambridge Soundworks 88CD CD Player Logo
173 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
