My EMERSON LC320EMXF VOLUME GOES UPPER AND DOWN AND THE MENU SCREEN POPS UP
4 Suggested Answers
SOURCE: Emerson TV LC320EMXF Remote code for Direc TV
I got the same TV for my stepdaughter and had the same problem. None of the Emerson codes worked. We use Dish Network but I did the autoscan thing on the remote and found that it was 672 which is listed as a Sylvania. I don't know if it will help in your case but maybe try the Sylvania codes. Good luck.
Posted on Dec 25, 2009
  • 290 Answers
SOURCE: why does my 26 insignia do the following without
It could well be your remote control has a problem. Try removing the batteries from the remote control and see if the problem goes away, if it does, try new bateries on the remote controller, if that does not work you may have to get a new remote controller
Posted on Mar 24, 2010
SD Tech
  • 14553 Answers
SOURCE: I have a emerson LC320EMXF 32 in tv and the volume
If it only goes up or only down that is fairly easy to find.
if goes up and down both what is hooked to it for signal and how--cable etc and via rear jacks or coax fitting from (are you using a box?)
A simple test is to connect a DVD etc. to one of the rear inputs and see if same problem that way.
Posted on Apr 17, 2012
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
When i turn it on,it goes through the entire menu and won't stop
first check all your push buttons on the TV to be sure none are jammed or sticking, then if that doesn't solve the problem you will need the PCB part# A91F0MPW-001
see the following site for part avail. & price:
https://www.encompassparts.com/item/8098042/Philips/A91F0MPWS001/Main_Pwb%28non-returnable%29
Mar 03, 2015 | Emerson LC320EMXF 32 in. LCD TV
Emerson tv problems
If you are using a cable or satelite box, the problem could be from mismatch of the volume level between the TV & the source. This is solved by properly adjusting the 2 volume levels to eliminate the buzz.
The issue could also be either your speakers or Input/Output PCB.
Also be sure it is coming from the speakers.There have been some issues of buzzing caused by vibrating transformers on circuit boards,
Jul 24, 2014 | Emerson LC320EMXF 32 in. LCD TV
Volume go down automatic
The other "solution" is wrong.
the most common reason:
Jan 08, 2013 | Emerson LC320EMXF 32 in. LCD TV
I have a emerson LC320EMXF 32 in tv and the volume goes up and down on its own. Will someone help me with problem.
Apr 17, 2012 | Emerson Televison & Video
I just got dish network installed and I cant use the remote to use my tv I have a emerson tv model # lc320emxf can you help
Hello!!! You will just want to program that remote using these easy steps. GoHope this helps!!!
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
672
632
654
Becki Barned
DISH Network Customer Service
Feb 07, 2011 | Emerson LC320EM9 32 in. LCD HDTV
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
