Question about Car Audio & Video
My truck will start when in the mornings but i cuts it off and try to start it again it wont. I bought a crank sensor and it still didnt work the scanner says the engine temp was -40 so i bought a thermostat and i got an throttle position sensor because it kept idle
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
you need to replace the start candles that heat up the motor before start.
Thanks
Posted on Nov 22, 2013
I have a 2005 Nissan Hardbody 3.3l V6 4x4. In the morning, you start and drive for long hrs no issues. The problem starts after switching it off, and when its hot. It cuts off, you crank up until batt
Sounds like a "HOT SOAK" problem.
Starter gets hot,it lacks power to crank the engine.
Possible "Vapor lock".
Check for engine codes.Possible bad temp sensor for ECU.
If fuel delivery is suspect ,try starting fluid into intake when "no start" occurs to diagnose fuel problem.
May 19, 2014 | 2007 Nissan Hardbody 3000TD
Motor wont start
do you hear the fuel pump working? and did you check the fuses? also check and see if the fuel cut of switch is on. it was typically located in the trunk by the hinges that hold th trunk or on the side but look in your owners manuel or google it. i would guess fuel pump in honesty.
Apr 14, 2014 | 2000 Ford Taurus
CAR WONT START
CKP sensor or cam sensor. one goes bad and causes other to go bad. easy fix and not too expensive.
Mar 13, 2014 | 1999 BMW 318 ti
2003 bmw xi will not crank
There is a resistance or cut oout problem in the cluch fan circuit.
Nov 17, 2013 | 2003 BMW 330 xi
Got an 85 f350 6.9 diesel I went to start it this morning it cranked slow didnt start so went to crank again it wont glow plug or crank from key.What could be my problem???
sounds like you have a faulty ignition switch or a burnt fusible link(located on the right fender next to the battery).
Feb 10, 2011 | 1986 Ford F 250
My sons jeep grand cheeokee started cutting out and then died i got it running and got it home put some fuel injertor cleaner in it then this morning it turned over but wouldnt fire. my other son put a new...
At the back of the engine in between the trans. and engine is a crank sensor. It's on the pass. side of the block. Follow the crank sensor wiring that runs under the engine to see if the harness is broken. If it's in good shape then replace the crank sensor.
Mar 29, 2010 | 1995 Jeep Grand Cherokee
235k miles. cut off one time going down road, immediately restarted. a week later after cutting off would not restart in 8 long cranks. 5 mins later cranked. next morning after starting 2 different time...
I have seen crank sensors go and leave no codes, but, likely the fuel pump is going away...they get hot and seize, then cool down and work again. I would not replace either without proper testing only because parts are expensive and there are other heat sensitive components in there. (coil etc) Be aware that it will check out good if it is running right while tests are being done.
Sep 24, 2009 | 2000 Jeep Cherokee
Grand am gt 2000 3.4 liter,,,fule pump or filter
you need to check to see if you have fuel pressure at fuel rail.if not suspect the fuel pump .if you do have fuel pressure replace the crank sensor.located by passenger side. behind crank pulley
Jan 30, 2009 | 2000 Pontiac Grand Am GT
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
